Potential new project
  • donebysunday
    • Oct 2012
    • 1737
    • New Berlin, Wi.
    #286
    Sorry James, I just have to ask,,,,,,, did you send the frame out for powder ?
    Was the engine also powdered ? TIA ! Don'e
    76 XS650 C ROADSTER
    80 XS650 G Special II
    https://ibb.co/album/icbGgF
    80 XS 1100 SG
    81 XS 1100LH/SH DARKHORSE
    https://tinyurl.com/k6nzvtw
    AKA; Don'e, UD, Unca Don'e
    • Prisoner6
      • Aug 2013
      • 1184
      • Phoenix, AZ
      #287
      Here they are again... hopefully working this time..... I have to keep them short as the iPad won't send bigger files...
      This first one is a cold start with the choke on first position
      This one shows the choke taken off and normal running....
      The "PROJECT" is sounding great to me, James ...
      Good job!
      Marco
      1979 Honda CBX
      2002 Kawasaki ZRX1200R
      WE MISS YOU, DON
        • 6765
        #288
        Stunning Work James!!!
        What a cracking motor!!!
        What is that ring on the side of the rear fender under the rear seat cowl? Registration or road tags?
        2005 Honda SilverWing 600
        2018 Honda PC-Xpress 150
        • James England
          • 3039
          • North of England
          #289
          Yes done, I sent the frame for powder coating. I soda blasted the engine and used black VHT enamel.......
          • James England
            • 3039
            • North of England
            #290
            Thanks. it's a road tax disc. They were got rid of this year, so no more bikes marred by that thing!
            • James England
              • 3039
              • North of England
              #291
              Good job!
              Thanks, Marco. The sound on the vids is deceiving. The engine actually sounds exactly as it should.....
              • donebysunday
                • Oct 2012
                • 1737
                • New Berlin, Wi.
                #292
                James if I may please ? Small bits were sent with the frame for powder, like triple tree, center/side stand, switch gear, headlight, gauge covers, foot pegs, mid/FD, etc. ?
                How much beside engine is done with VHT ?
                I take it then that the VHT is durable enough for normal abuses and possible minor fuel/oil spills ?
                I put together a VHT kit to do an exhaust consisting of 2K° flat blk and clear, looks good on my sample I now have a couple exhaust sets rough enough to use it on.
                Are you using the standard gloss blk VHT ?
                Sorry I ask so much, prying into your methods but I'm compelled by the artistry of your work !!!!!
                TIA Don'e
                76 XS650 C ROADSTER
                80 XS 1100 SG
                • James England
                  • 3039
                  • North of England
                  #293
                  TIA Don'e
                  heck, Done, none of it's a secret. I only sent the frame, swing arm, battery holder, rear fender brace, stands and a few other bits for powder coating. The triple tree is black xylene paint and the switch gear is PJ1, although next time I'll use VHT instead as PJ1 in Europe has been emasculated chemically! Gauge covers are VHT.
                  The VHT dries in a few hours but it has to be cured at 100c for an hour and then acquires resistance to chemicals etc over the next few weeks. It is OK for minor spills althoughI tested a bit by dunking it in gasoline.....it came off! But, in normal use it's fine.
                  For you in the USA, PJ1 Satin black case paint is where it's at. You still have the old, unadulterated formula which is brilliant. I spoke with PJ himself earlier this year,as he phoned me from the USA to confirm that the EU had banned his product and that it had been changed to something inferior. He actually admitted it and said how sorry he was. But, for now, you have the proper stuff jb the USA. I would use that if I could get it as it is 99.9% like OEM and nothing shifts it...
                  • James England
                    • 3039
                    • North of England
                    #294
                    Viton update
                    Just a quickie to say that the Viton chunks I used between the cooling fins are absolutely fine, even with a really hot engine. There's no sign of shrinkage, or melting or anything untoward........
                    • James England
                      • 3039
                      • North of England
                      #295
                      Mirrors
                      Hi Folks
                      I found some mirrors which closely match the oem ones that came on the European models. They are not expensive either.... I got them on eBay...
                      Here's a link to the seller. He's in Germany...
                      http://www.ebay.co.uk/itm/3102883006...%3AMEBIDX%3AIT
                      One other point...I upgraded my remote fuel tank from an empty oil container to a luxurious grass mower tank. It really is ideal for tuning the bike...no fuel tank propped up to get at the adjustment screws and get damaged. It makes life much easier (and a lot safer) when syncing or testing carbs for leaks etc. I ran a single piece of pipe to a T-piece. The tank cost me $1 on eBay!
                      • Aches n Pains
                        • 349
                        • Reston, Va.
                        #296
                        Damn, that's a pretty bike.
                        1995 KZ100P
                        Pods, jets, pipes, cam adjuster, oil cooler
                        1977 Ironhead - custom build
                        Hot engine, custom frame, KZ front and rear, high torque starter, alternator conversion, Progressive shocks, Thunderheart wiring, Dyna ignition, oil cooler, Dakota Digital instruments, etc.
                        Sold all my XS's to Eastcoaster but still love to keep up with you guys. This is the best cycle forum on the web.
                        • James England
                          • 3039
                          • North of England
                          #297
                          Thanks. This current project should come out looking like the complete bike in the pix. Probably a little bit better. I'm waiting for the tank and panels to come back from the sprayshop and should have them in about ten days. So, hopefully I'll be posting pix of the completed project very soon!
                          The last bike I did is actually up for sale, I discover yesterday.... http://www.carandclassic.co.uk/car/C440211
                          • James England
                            • 3039
                            • North of England
                            #298
                            Carb bits
                            I'm looking for four of the plastic covers that go on top of the mixture screws on the carbs... They are usually white or yellowish with age and they push on top of the four mixture screws at the front of the carbs, just near the inlet manifolds. Can anyone sell me some please? Or I could do a nice deal on a couple of rear left side wheel bearings as a swap
                              Do you have a well stocked hardware store? You may find small nylon caps there, or perhaps something I've not thought of.
                              • James England
                                • 3039
                                • North of England
                                #300
                                Yes, but the thing is, I have to get OEM caps etc for my rebuild projects. They have to be as close as possible to original. The OEM caps have screwdriver slots in them and a little bit that sticks out, supposedly to stop people messing with the emissions.
