Very nice write up sir, thank you!
Carb Synching 101
I know this is a stupid question but do you place the vacuum lines from your sync tool on the actual carbs or the carb manifold boots? Also, when done with the sync do you cap the vacuum port that isn't being used by the vacuum advance and the petcocks? Thanks1979 xs1100f
New Fuse Box
Progressive Shocks
Gold Valve Emulator
Dyna Coils
Electronic Flasher
Led Headlight
Led Turn Signals
4 Led Driving Lights
2nd Gear Fix
Auto Cam Tensioner
Digital Dash
Stainless Braided Lines
R6 4 Piston Calipers
Stainless Bolt Kit
Maier Fairing
Dyna Balancing Beads
Spin On Oil Filter
Stebel Nautilus Horn
Plasti Dip Rims
ISO Grips
Use the prime position on your petcocks when syncing and then hook everything back up the way it's supposed to be when your done..........
The vacuum advance DOES NOT GET DISCONNECTED.Greg
Originally posted by BA80 View PostUse the prime position on your petcocks when syncing and then hook everything back up the way it's supposed to be when your done..........
Has anyone used this tool, just got it and was wanting one since my first 4 cyl SF11 ?
Thanks, Done76 XS650 C ROADSTER
80 XS650 G Special II
https://ibb.co/album/icbGgF
80 XS 1100 SG
81 XS 1100LH/SH DARKHORSE
https://tinyurl.com/k6nzvtw
AKA; Don'e, UD, Unca Don'e
The vacuum advance DOES NOT GET DISCONNECTED.1979 XS1100F
As you said.
It's the intake manifold vacuum hoses that should be disconnected to allow for the sync gauge lines to be installed.
I agree, the intake manifold caps/plugs and the octi. vac. hose need to be put back on when your done syncing that side, the vacuum advance is not touched, it's left connected to #3 carb.
Sorry for my confusing the issue.
Been wondering if I screwed up my brain in that crash. Seems most everyone I know is taking offense at something I said, losing friends and relatives left and right.
Has anyone used this tool, just got it and was wanting one since my first SF11 in 79 ?
80 XS 1100 SG
Yes, I have one, and another more expensive MP 90 degree. Very useful tool, but the cheaper one only has a Phillips bit if I recall.1979 XS1100F
I have one very similar. It's an old Snap On carb adjusting tool for QuadraJet carbs. The bits are interchangeable. It's 1/4" drive and you can put any bit or socket on it.Greg
Yes, this is a very well written post.
Only thing I would say is about technique and not the order of things. That would be DO NOT GET IMPATIENT AND RUSH! It takes a few minutes to get a good sync so set up a fan to cool your motor.
Each adjustment should be very small in fact just, resting a screwdriver on the sync screws can show a change the vacuum reading for that cylinder. So make small adjustments one at a time and then let the motor idle for about a minute to give all the carbs a chance to even out. Remember an adjustment on one carb actually affects them all.Mike Giroir
79 XS-1100 Special
Correction if I may . . .
Originally posted by IanDMacDonald View PostHi Done- I believe you read that wrong, as Greg stated the VACUUM ADVANCE tube connected to the #3 carb stays connected. It's the intake manifold vacuum hoses that should be disconnected to allow for the sync gauge lines to be installed.
Your welcome in advance1980 XS1100G "Dolly G" Full Dresser (with a coat of many colors )
Originally posted by Schming View PostThe Vacuum advance hose is connected to the #2 carb, second one in from the left as you sit on the bike.
Your welcome in advance1979 XS1100F
So on the 78-79 carbs, when adjusting the idle screw, that large spindly looking wheel/screw, how do you turn it one why or the other, is there a special tool or does one just use a screw driver. Also, if you adjust this one wheel/ idle screw, I presume it adjusts the idle on all four carbs evenly?
Thanks, nice post.
d-179 SF
It has notches 360 on it. Use a flat-blade and push one way or the other.1979 XS1100F
Originally posted by dolphans1 View PostSo on the 78-79 carbs, when adjusting the idle screw, that large spindly looking wheel/screw, how do you turn it one why or the other, is there a special tool or does one just use a screw driver. Also, if you adjust this one wheel/ idle screw, I presume it adjusts the idle on all four carbs evenly?
Thanks, nice post.
d-176 XS650 C ROADSTER
80 XS 1100 SG
Originally posted by donebysunday View PostYes using a long flat blade, as long as that screw is movable/not froze up, poke it in the groove CW to increase RPM. CCW to lower RPM.. Yes it controls all the carbs, so you should not need to sync. them again. On the other hand it does not hurt to check sync. anytime your up to it. I had some mercury that I bought in 79 for my SF 8 lb. after my carb styx got messed up I made my own with the last of the mercury I had. But I wanted to try other homemade tools for this. I took 2 cycle oil mixed with fuel, enough to give it color so I could see it and. made a equalizer, it works but is very sensitive, you must have the carbs set really close or they will just suck the mix out of the tube, might be good for doing the idle mix screw sync. ?
Can the the throttle cable be adjusted near the the throttle grip near handle bars, where that chrome nut linkage meets the throttle grip? What is that nut for, to remove slack from cable?
Thanks,
d-179 SF
