Carb Synching 101
  • ESJr1642
    • Jan 2012
    • 103
    • Groveland, FL
    Very nice write up sir, thank you!
    1979 XS110F, Stock
    1980 XS1100G, Mostly Stock, gifted to my son.
    2000 YZ 250, Sold
    2002 YZ125, Sold
    2009 Royal Star Venture
    '94 Pontiac Trans Am, 25th Anniversary, For Sale
    Ernie
    • TheRev
      • Jun 2012
      • 235
      • Madison, Wi.
      I know this is a stupid question but do you place the vacuum lines from your sync tool on the actual carbs or the carb manifold boots? Also, when done with the sync do you cap the vacuum port that isn't being used by the vacuum advance and the petcocks? Thanks
      1979 xs1100f
      New Fuse Box
      Progressive Shocks
      Gold Valve Emulator
      Dyna Coils
      Electronic Flasher
      Led Headlight
      Led Turn Signals
      4 Led Driving Lights
      2nd Gear Fix
      Auto Cam Tensioner
      Digital Dash
      Stainless Braided Lines
      R6 4 Piston Calipers
      Stainless Bolt Kit
      Maier Fairing
      Dyna Balancing Beads
      Spin On Oil Filter
      Stebel Nautilus Horn
      Plasti Dip Rims
      ISO Grips
        Use the prime position on your petcocks when syncing and then hook everything back up the way it's supposed to be when your done..........
        The vacuum advance DOES NOT GET DISCONNECTED.
        • donebysunday
          • Oct 2012
          • 1737
          • New Berlin, Wi.
          The vacuum for the octi does get disconnected, that is why you need to switch to prime. Put the caps back or hook the octi back up on the carbs your not/done syncing.
          Has anyone used this tool, just got it and was wanting one since my first 4 cyl SF11 ?
          Thanks, Done
          76 XS650 C ROADSTER
          80 XS650 G Special II
          https://ibb.co/album/icbGgF
          80 XS 1100 SG
          81 XS 1100LH/SH DARKHORSE
          https://tinyurl.com/k6nzvtw
          AKA; Don'e, UD, Unca Don'e
            • 4015
            Hi Done- I believe you read that wrong, as Greg stated the VACUUM ADVANCE tube connected to the #3 carb stays connected. It's the intake manifold vacuum hoses that should be disconnected to allow for the sync gauge lines to be installed.
            • donebysunday
              • Oct 2012
              • 1737
              • New Berlin, Wi.
              As you said.
              I agree, the intake manifold caps/plugs and the octi. vac. hose need to be put back on when your done syncing that side, the vacuum advance is not touched, it's left connected to #3 carb.
              Sorry for my confusing the issue.
              Been wondering if I screwed up my brain in that crash. Seems most everyone I know is taking offense at something I said, losing friends and relatives left and right.
              Has anyone used this tool, just got it and was wanting one since my first SF11 in 79 ?
              Thanks, Done
              76 XS650 C ROADSTER
              80 XS 1100 SG
                • 4015
                Yes, I have one, and another more expensive MP 90 degree. Very useful tool, but the cheaper one only has a Phillips bit if I recall.
                  I have one very similar. It's an old Snap On carb adjusting tool for QuadraJet carbs. The bits are interchangeable. It's 1/4" drive and you can put any bit or socket on it.
                  • TADracer
                    • 1417
                    • Kenner, Louisiana USA
                    Yes, this is a very well written post.
                    Only thing I would say is about technique and not the order of things. That would be DO NOT GET IMPATIENT AND RUSH! It takes a few minutes to get a good sync so set up a fan to cool your motor.
                    Each adjustment should be very small in fact just, resting a screwdriver on the sync screws can show a change the vacuum reading for that cylinder. So make small adjustments one at a time and then let the motor idle for about a minute to give all the carbs a chance to even out. Remember an adjustment on one carb actually affects them all.
                    Mike Giroir
                    79 XS-1100 Special
                      • 2104
                      Correction if I may . . .
                      The Vacuum advance hose is connected to the #2 carb, second one in from the left as you sit on the bike.
                      Your welcome in advance
                        • 4015
                        You may very well indeed Schming, lol. I have mine capped-off, that's why I'm not too familiar with it like everything else.
                        • dolphans1
                          • Mar 2013
                          • 168
                          • Orlando, Fla.
                          So on the 78-79 carbs, when adjusting the idle screw, that large spindly looking wheel/screw, how do you turn it one why or the other, is there a special tool or does one just use a screw driver. Also, if you adjust this one wheel/ idle screw, I presume it adjusts the idle on all four carbs evenly?
                          Thanks, nice post.
                          d-1
                          79 SF
                            • 4015
                            It has notches 360 on it. Use a flat-blade and push one way or the other.
                            • donebysunday
                              • Oct 2012
                              • 1737
                              • New Berlin, Wi.
                              Thanks, nice post.
                              d-1
                              Yes using a long flat blade, as long as that screw is movable/not froze up, poke it in the groove CW to increase RPM. CCW to lower RPM.. Yes it controls all the carbs, so you should not need to sync. them again. On the other hand it does not hurt to check sync. anytime your up to it. I had some mercury that I bought in 79 for my SF 8 lb. after my carb styx got messed up I made my own with the last of the mercury I had. But I wanted to try other homemade tools for this. I took 2 cycle oil mixed with fuel, enough to give it color so I could see it and made a equalizer, it works but is very sensitive, you must have the carbs set really close or they will just suck the mix out of the tube, might be good for doing the idle mix screw sync. ?
                              76 XS650 C ROADSTER
                              80 XS 1100 SG
                              • dolphans1
                                • Mar 2013
                                • 168
                                • Orlando, Fla.
                                Yes using a long flat blade, as long as that screw is movable/not froze up, poke it in the groove CW to increase RPM. CCW to lower RPM.. Yes it controls all the carbs, so you should not need to sync. them again. On the other hand it does not hurt to check sync. anytime your up to it. I had some mercury that I bought in 79 for my SF 8 lb. after my carb styx got messed up I made my own with the last of the mercury I had. But I wanted to try other homemade tools for this. I took 2 cycle oil mixed with fuel, enough to give it color so I could see it and. made a equalizer, it works but is very sensitive, you must have the carbs set really close or they will just suck the mix out of the tube, might be good for doing the idle mix screw sync. ?
                                Thanks, I had my carbs checked for sync and they were spot on, once bike was fully warm or hot and choke off, the RPM's would slowly drop below 1000RPMs on idle and stall out, if I rotate throttle the throttle grip just a slight tad, and hold it there, the bike idles just fine.
                                Can the the throttle cable be adjusted near the the throttle grip near handle bars, where that chrome nut linkage meets the throttle grip? What is that nut for, to remove slack from cable?
                                Thanks,
                                d-1
                                79 SF
