New Guy Question
Yes Fred, but if they are all even it WILL run good and the idle can be adjusted up when you start it. Or, it can be set wider to begin with.
It's just the method that I've used repeatedly and works very well for me.Greg
Hi Jordan,
at least you didn't hardtail the bastard so there's hope for you yet.
Did you at least carefully save the parts you cut off so you can weld them back on once you realize how handy they were?Fred Hill, S'toon
"The Flying Pumpkin"Comment
I'm wondering if you have a sticking slide?XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.Comment
Another idea
If you've tried the more obvious suggestions, and still have the problem...and you're looking for more ideas...your symptoms seem really consistent with air leaks between the carbs and the intake manifold.
Usually the symptoms get worse as the bike warms up. Typically it happens when you have been riding, and you let up off the throttle and the idle doesn't go back down like it should.
The leaks can occur around the rubber boots, or the butterfly shaft seals in the carburetors. One trouble shooting technique is to let the bike idle and spray starting fluid or lighter fluid onto the suspected areas. The RPM will change dramatically if you happen to spray it over a leak.
Just another idea...-Mike
Previous: '68 Motoguzzi 600cc + '79 XS750SF 22k miles +'84 Honda V65Comment
