New Guy Question
  • penninger
    • Jan 2014
    • 14
    • Sacramento, CA.
    New Guy Question
    Hello everyone this is only my second post, well really it my first "real" post. I picked up my 1979 xs1100f for free off Craigslist and was told it didn't run, but it was a complete bike. And it has a clean CA title and that is something in and of it's self. So after some wiring, petcock rebuild, gas tank flush, cleaned the carbs, and a fresh battery the beast fired up.
    Now I am having an issue with the cold idle. If it even has a cold idle. I started the bike and let it run and the RPM's were at 3200 after a short time they dropped to around 1200. But after twisting the throttle a few times the bike would not idle back down. It stayed at a constant 3200 rpms. Any suggestions on why or how to fix this.
    79 XS11 Bobber Project
    First off, I hate you!! A standard model, complete bike, free of charge. Yes, I hate you.
    So, you cleaned the carbs, but have you tuned and synchronized them? Two things can cause a high idle like that, lean mixture and out of synch carbs.
    • penninger
      • Jan 2014
      • 14
      • Sacramento, CA.
      Only by ear. I have a buddy coming over this weekend to help me out with that part of it.
      Also the longer I keep the beast running the higher the RPMs get.
      Thanks for the quick response.
      • penninger
        • Jan 2014
        • 14
        • Sacramento, CA.
        The really funny thing is the guy I got it from said "I got this as a project but I cant even get it to turn over with a new battery." So after digging through the bucked of parts he gave me with it, I found the ignition box in a plastic bag. Plugged it in and instant life. lol Some peoples kids.
          If you did a bench sync (search the forum, instructions are here) and set all the mixture screws to about two turns out, you should be able to get it to run fine.
          • penninger
            • Jan 2014
            • 14
            • Sacramento, CA.
            Two turns out were perfect! She is idling right around 1100 rpms now. That should have been my first step but for some reason this was kicking my teeth in. Hey thanks again, and sorry for the noob question.
              Please don't apologize. This is why we're here.
              • penninger
                • Jan 2014
                • 14
                • Sacramento, CA.
                Ok so I'm back. I adjusted the carbs idle mixture screws and got the RPMs down. But and this is a big BUT. When I turned off the bike and came back to it the same thing happened. 4500 RPM's and just sat there.
                • dpotter58
                  • Aug 2004
                  • 1866
                  • Southern Maryland
                  get them all synched. good job on it so far. free is good
                  1980 LG
                  1981 LH
                    Make sure the throttle linkage ( where the cable hooks to the carbs) isn't catching on something. Maybe an intake boot clamp?
                    • penninger
                      • Jan 2014
                      • 14
                      • Sacramento, CA.
                      that was the first thing I check.
                        Do you have the carbs where it's easy to remove them?
                        • penninger
                          • Jan 2014
                          • 14
                          • Sacramento, CA.
                          yeah I can take them off in about 15 mins
                            Take them back off and bench sync them. Some people use something thin like a bread tie to get them close but I usually just hold them up to a light and eye ball them and usually get them within a fraction of a turn.
                            Just adjust them so there's a sliver of light showing equally in all 4. Put them back on and you should be very close.
                            • penninger
                              • Jan 2014
                              • 14
                              • Sacramento, CA.
                              Yeah thats a good idea. Stop messing around and pull them off. I found the thread on here about bench sync, so I'll follow that. Thanks
