Techna-Fit S/S Brake Lines (4-Line kit)- $90+s/h
  • Newbee
    Truly XSive (Deceased)
    • Jul 2011
    • 160
    • Whitby Ontario, Canada
    s/s brakes
    Ordered mine yesterday received tracking email today my order has been shipped.78-80 e f g the same 79-81specials same need to send in a set 1981H different due to fairing again need to send in a set.Lucky me I have an 80g.thanks Ian.
      The fairing does not make it different, lines run the same either way. However, I think the H had the buckhorn bars or they had their own special bars. Different bars and a different MC are what change the line length and fitting angles..
        • 3193
        On a side note to any of you who order from this guy....You should get your lines for free if he is making a pattern from them to sell to others. Also note that the stainless lines are less forgiving (as was previously mentioned) so any copied from original stock rubber lines may not end up perfect. I believe that is why the coastguard lines were making some happy but not others.
        Kudo's for finding another supplier is also in order to Ian. Anything done to make parts and supplies more readily available to the XS11 Rider is appreciated.
        • MPittma100
          • Aug 2011
          • 2359
          1981h
          I put a set of Chacal SS lines on a 1981H. Don't think there was any difference between it and the other Standards.
          1981 XS1100H Venturer
          K&N Air Filter
          ACCT
          Custom Paint by Deitz
          Geezer Rectifier/Regulator
          Stebel Nautilus Horn
          EBC Front Rotors
          Limie Accent Moves On In 2015
          Mike
          • MPittma100
            • Aug 2011
            • 2359
            Pictures
            Here are pictures of Techna-Fit lines for the XS1100:
            K&N Air Filter
            ACCT
            EBC Front Rotors
            Mike
              • 4015
              Where did you get those pics from, lol?
                Hi Don,
                I have heard that the H has different handle bars. Not buck horns.
                I do not know if mine has original or not. Hence my hesitation to just order these lines.
                • MPittma100
                  • Aug 2011
                  • 2359
                  Pictures
                  Pictures came from (where else?) the source - (Techna - Fit).
                  K&N Air Filter
                  ACCT
                  EBC Front Rotors
                  Mike
                  • Orange4
                    • Sep 2013
                    • 398
                    • Maple Ridge, B.C., Canada
                    I'm trying to figure out what they mean by "clear" with those lines. It sounds like the woven stainless lines are covered by a clear plastic. Black are covered by black plastic, etc. I was leaning towards stainless for a lighter look but in my experience clear plastic always yellows over time. Has anyone received a set yet?
                    Living to EXcess.
                    1979 XS1100F Canadian, stock exhaust. Top end rebuild in progress.
                      Keep in mind that the Special calipers differ from the standard as well. The bottom banjos may require a different angle. If I were going to order lines for a Special from Techna-Fit, I would send them the original lines and let them match them up.
                        • 4015
                        Yes, I have. See my product evaluation of these.
                          I know that Ian. You provided the template for the F. The Special fronts will be different.
                            • 4015
                            Sorry Marty, I should have quoted Orange4 "Has anyone received a set yet?".
