T.C., Yes a lot of guys over here did think that they came with the big tank, but in all cases, they've been swapped over at some stage. Ex factory, they all had the 15 litre Special tank.
In saying that, it probably wouldn't have been a real hassle getting the dealer to fit a bigger tank if the customer asked for it.
Other than the tank, Jim's (ozlad's) Rh only differs from stock with the horns, rack, caseguards, seat (been recovered but stock shape), 4-1 exhaust, the little dash panel above the guages with the clock mounted in it, and the sidecover badges have been changed from the normal 1.1 to those XS eleven stickers.
DaveyG, the regulations regarding production bike racing back in the day were very strict. The bikes had to be run absolutely stock standard, with no deviation from the shop manual.
There was one year when BMW won the six hour with the R90 and they got excluded from the results because the fork spring preload spacers were found at to be fitted below the springs instead of on top, as per the shop manual.
So swapping tanks was definitely out of the question.
I've heard of other cases where bikes have had the fuel tank blown out slighty with compressed air to give a trifle more capacity, but these were discovered during routine scrutineering, where everything is checked, firstly with placegetting bikes, then right through the field till they were all checked and official results were then posted up (sometimes, it took weeks)
