Xs1100r
  • mrbill204
    • Sep 2013
    • 7
    • Rossville Georgia
    Xs1100r
    Any information on the XS1100R
    XS11
    Are you talking about the RH Australia/New Zealand version?
    That is the only. One with an R in the designator.
      If you want one on this side of the planet, I believe you have to build it yourself.
      • MPittma100
        • Aug 2011
        • 2359
        Xs1100r
        Well, I will be darned. Never heard of this one. Learn something new every day!
        Mike
        1981 XS1100H Venturer
        K&N Air Filter
        ACCT
        Custom Paint by Deitz
        Geezer Rectifier/Regulator
        Stebel Nautilus Horn
        EBC Front Rotors
        Limie Accent Moves On In 2015
        Mike
          It is similar to a 81 MNS but with the rare swirly 17" rear rim and no gold trim. Nice lookin' bike.
            Yeah, lots of unobtainium parts for those of us in the US.....
            Even the guys down under have trouble finding some of the parts on these.
            • XS1100 Newbie
              • Jun 2009
              • 1106
              • Battle Ground, Washington
              It looks like it has clip ons for bars. I want!!
              1980 XS1100LG Midnight
              1991 Honda CBR1000F Hurricane
              A cold beer and another one!
              • Eveready1100
                • 539
                Correction, It LOOKS similar to an 81 MNS, but appearances are deceiving.
                The RH is virtually the same as the Euro "Sport" model, but with detail changes to conform with local design rules.
                The photos in this RH brochure are actually photos of the Sport, not the RH, for some reason.
                The main difference between either the RH or Sport to the Specials is the frame.
                It's dimensions are virtually identical, but it's constructed out of thicker walled tubing and is gusseted at every tube junction for greater strength and rigidity.
                Here's some pics of a bare RH frame
                ^ see all the gussets? Factory frame hot rodding.
                ^ even the lower joints got some.
                ^ and the back end. The upper shock mounts also have thicker bracing compared to either the special or standard models.
                Large box brackets under frame mount a large flat profile brace under the motor and inner pipes.
                ^ and this shot shows the extra cross tube where the tank mount is.
                ^ The handlebars aren't clipons, they're 3 piece bars that fit normally, with adjustable sweep angle. Here's a set compared to the Standard's Eurobars to show the lower rise.
                And if you look closely at the brochure pic of the rear wheel, you'll see that it's a swirly 17 inch rim with rimlocks.
                That leaves cosmetics, such as the fairing (to fit an 8 inch headlight in) and seat, mudguards etc which make these quite unique.
                It appears that these bikes were intended to contest in production racing where the earlier Standard models had fared so well, but they missed the boat badly by the fitment of the Special's tank, which may be a lot more stylish than the big ones, but the majority of production races over here were endurance events, mainly of 2, 3 and 6 hour duration, in which having a bike which probably wouldn't do an hour at full noise without refuelling would be a real problem. ( This is the main reason why Suzuki Katanas also dipped out , as they had small tanks compared to the equally powerful GSX1100's)
                • daveyg
                  • Feb 2009
                  • 411
                  • Boise, ID
                  Oooh! Me likey! If only it had a standard tank, it would be perfect! It would be the most gorgeous motorcycle ever! (In my opinion) they couldn't just throw on a standard tank for racing?
                  BARE BONES CHOPPERS: If it don't make it go faster, you don't need it!
                  80 XS1100SG(cafe in progress *slowly)
                  • MarkD
                    • Jun 2013
                    • 488
                    • N. Michigan
                    This bike looks like it's a new scooter made to look retro, ala Triumph or the new Honda. I thought the '79F was the coolest, but this one is its rival.
                    79 F
                    1967 Suzuki X6 Hustler
                    1973 Suzuki TM 125
                    1979 XS1100 F
                    2005 Kaw. Vulcan VN800
                    1991 BMW K75
                    • scratcher09
                      • Dec 2013
                      • 19
                      • San Antonio, Tex.
                      Those look like the swirly wheels that were on my '81 Virago.
                      80 LG
                        If I could have my choice of any, I would choose the R. I like it a lot.
                        • MarkD
                          • Jun 2013
                          • 488
                          • N. Michigan
                          Don't know if I'm doing this right, but there are a few pics to peruse here:
                          79 F
                          1973 Suzuki TM 125
                          1979 XS1100 F
                          1991 BMW K75
                            Just thought I'd pull the photos into this thread, surprising that these are the "R" with the Standard tank, and the fellows in Oz said that they were this way STOCK!
                            Very interesting regarding the frame gussets. Wish I had known about these 13 years ago when I did my rebuild, I would have then taken my bike down to FRAME to add the stabilizing changes! I'm just a bit too lazy now to do it again, as long as my bike runs!
                              • 2104
                              Hi T.C., if one was to add the gussets and bracing, what would be the optimum weld procedure of choice ?
