What shock absorbers do you prefer
    Here is how I have mine ran. I had never thought to run it under as Greg suggested, Might make that change. It does work as shown, but note that I did forget to keep it out from under the seat rubber cushion once.
    As you can see the air fill is not in the way of any components, easily accessible....
    And yes, I do use the helmet lock, often.
      • 9980
      Ha ha ha...... that's 1.
      • Prisoner6
        • Aug 2013
        • 1184
        • Phoenix, AZ
        XJ air shocks
        Originally posted by BA80
        You have to remove the helmet lock and route the air hose up around the top rear of the tool box, but yes.
        So, are the options for finding a pair limited to Ebay, or maybe Andreas here on the site? Saw a few pair on Ebay tonight ...
        Marco
        1979 Honda CBX
        2002 Kawasaki ZRX1200R
        WE MISS YOU, DON
          Ha ha..don't know anyone who uses that helmet lock anyway
          I use the helmet lock. I don't expect it to stop someone who wants my helmet (don't know why anyone would though) it is just someplace to keep the helmet rather than having to carry it around with me.
            • 9980
            I've always gotten them from fleabay. If your patient enough you can get a really good price.
            2
            • jwhughes3
              • 2798
              • Home of the Alamo
              The lock can be relocated to the rear bag crash bars (there is a mount point for it) if you have those or just get one that mounts to the handlebar.
              If my helmet one of those really high $ models I might lock it but mostly just leave it on the highway pegs.
              John
              '81 XS1100H - "Enterprise"
                • 2072
                The lock can be relocated to the rear bag crash bars (there is a mount point for it)...
                Or for them: (And I keyed them alike)
                  Hi Schming,
                  I have one at the back like yours. I use it quite a lot. However it still hangs the helmet upside down like a bucket to catch the rain
                    • 2072
                    Hi Schming,
                    Hi Phil,
                    On the overly humid days I'll store the half helmets in the trunk, or if it's loaded I always have a couple plastic bags with me.
                      • 3221
                      Another shock option is a pair of Showa shocks. Direct bolt on to m 80SG, got them on eBay...
                      Here's a link to the thread from this forum.
                      ZRX1200
                        • 3918
                        Originally posted by Brent
                        I am running Showa air shocks; stock on a Harley davidson FLH; Roadking electraglide, etc. 35 psi max. Take offs about $25. I believe the same shock is used on some honda goldwings. I changed the rubber eye grommets, putting the Yamaha rubber part into the showa eye, so as to fit stock XS bolt. Also ground small portion off shock corner to clear helmet lock. Much improved over worn out stock XS shocks.
                        Good luck wrenching
                        Will these, or for that matter the XJ air shocks be a direct bolt-on for standard rear shocks?
                        • Murphyslaw
                          RESIGNED MEMBERSHIP by REQUEST
                          • Jan 2014
                          • 40
                          • Sacramento, CA.
                          I went from some what I believe to be some old school busted up Harley shocks to new school Harley progressives. I gotta say its a very firm ride, but it keeps me planted on the ground where as before I spent most of my rides flying through the air like Aladdin.
                          79 XS1100
                          fj1200 carbs
                          Dyna green coils
                          2nd gear fix
                          Frame cut w/ 06 nightster seat
                          RPM dual UNI pod filters, open headers
                          Clubman bars, drag specialties speedo, xj headlamp
                          Deleted fenders, Barnett springs
                          23 Yrs. old livin' life at 125mph
                          • Mathh
                            • Nov 2006
                            • 668
                            • Beek, Netherlands
                            Overhere we have Ikon (former Koni), Wilbers Suspension (WP), Bitubo, Hyperpro, Technoflex all of which can make shocks for XS1100. ikon being the cheapest (relatively speaking). Normally I would go go for the Ikon and sometimes for the Ohlins by Yamaha which are standard on the XJR1200/1300 (just replace one bushing) if I find them used on ebay.
                            MV Agusta Brutale 910R '06.
                            Yamaha MT-09 Tracer '15 grey.
                              • 7804
                              Bitubo is available on this side of the pond. I'm told it's a good economical option.
                                • 3918
                                Bump for an answer.
