What shock absorbers do you prefer
  • Sylvester
    • Nov 2013
    • 12
    • Bessemer City, NC
    I need to replace the rear on my new2me XS Eleven Special. I see Progressive and Hagon advertised. Are there other options?
    Jim Parks aka Sylvester
    Where did all the years go? I think I slept through the last two decades.
    2002 Royal Star Venture
    1980 XS11SG
    • 8736
    There are the Chinese JCW economy shocks, if you are a heavier rider or ride 2 up, the springs will be too weak. I have used these and adapted the stock XS11 springs (not a direct fit) and they work ok. Some fellas use Honda Shadow shocks.
      • 7808
      YSS is an economical quality option.
        I fit the XJ1100 airshocks on mine. They work good for me.
          • 9980
          +1.
          The XJ shocks make an XS a totally different bike.
          • Prisoner6
            • Aug 2013
            • 1184
            • Phoenix, AZ
            Originally posted by BA80
            +1.
            Greg,
            Can you explain HOW the XJ shocks make an XS a totally different
            bike? Is it better ride quality? More adjustability? Better handling?
            Thanks ... I'll stop asking questions now and start listening ...
            Marco
            1979 Honda CBX
            2002 Kawasaki ZRX1200R
            WE MISS YOU, DON
              • 9980
              Originally posted by Prisoner6
              Greg,
              All of the above.
              • baltimorenick
                • Jun 2009
                • 43
                • Baltimore, MD
                I bought a set of YSS shocks a few month ago. They are great quality for the price. When you order from them, you specify your weight, your passenger's weight and the percentage of riding time that you expect to do solo, 2up, touring, etc. They will select springs that they think will suit you the best. I've put about 3k on them so far and immediately took a trip from Maryland to Maine the day after I installed them. It was a very noticeable improvement compared to my failing stock SF shocks.
                XS1100SF daily rider
                XS1100F (parts/project bike)
                • Cobia
                  • Jul 2007
                  • 1587
                  • Palm Beach County, Fl
                  I replaced my worn shocks with 2009 (IIRC) Shadow 1100 shocks and the ride improved dramatically. You can find them on cheapbay for next to nothing and there are no springs exposed.
                  1980G Standard, Restored
                  Kerker 4 - 1
                  850 Rear End Mod
                  Automatic CCT
                  1980GH Special, Restored
                  '82 XJ1100 (Sold)
                  • jwhughes3
                    • 2798
                    • Home of the Alamo
                    Greg,
                    I switched from Progressive HD to XJ Air Shocks and agree with Greg it totally changes the bike in a good way. Less tiring to ride LD.
                    John
                    '81 XS1100H - "Enterprise"
                    • Brent
                      • 959
                      showa
                      I am running Showa air shocks; stock on a Harley davidson FLH; Roadking electraglide, etc. 35 psi max. Take offs about $25. I believe the same shock is used on some honda goldwings. I changed the rubber eye grommets, putting the Yamaha rubber part into the showa eye, so as to fit stock XS bolt. Also ground small portion off shock corner to clear helmet lock. Much improved over worn out stock XS shocks.
                      Good luck wrenching
                      Brent in GA
                      • Prisoner6
                        • Aug 2013
                        • 1184
                        • Phoenix, AZ
                        XJ air shocks
                        Are the XJ air shocks a direct fit/bolt-on for a '79 SF?
                        Marco
                        1979 Honda CBX
                        WE MISS YOU, DON
                          • 9980
                          You have to remove the helmet lock and route the air hose up around the top rear of the tool box, but yes.
                            I swapped the gromets left to right and did not need to remove anything. I'll try to get a pic tonight.
                              • 9980
                              Ha ha...I don't know anyone who uses that helmet lock anyway and the hose lays pretty naturally along the top rear edge of the tool box.
