crap....
  • b.walker5
    • Feb 2009
    • 1745
    • Invercargill, New Zealand
    Just connecting a charger to the battery in bike shouldnt blow a 30 amp fuse. Even on a dry battery, the most your going to deliver from a 2 amp charger is 2 amps. It would make no difference to the charger if the cells were shorted, other than it wouldnt charge. Theres no way the charger cold blow that fuse. I would be looking for the cause of that. Was it blown, as in link disintergrated by a high current surge, or was it melted in the middle due to an extended period of current at, or just above the rating of the fuse? Bearing in mind that fuses of that type are 'coarse' current protection and can handle up to 1.5 x their rating for up to 4 hours before blowing. Either way, blowing the fuse will be due to something downstream from the battery.
      IMO, I would suspect a voltage drop(weak connection), as the regulator just 'reads' a low voltage and continues the charge at the higher amp.(14.2+) constantly overcharging the battery. Worth checking the whole system with a meter in hand as that style of replacement battery WON't be as forgiving as the previous one was if there's an overcharging rate going on.
        • 6762
        not sure abt any of this...I'm no electrical guru so maybe i can get this over to someone who does know...to have the whole thing checked out
          Would be my choice, if nothing more than 'peace of mind'.
