Did you follow the link in the Tech Tip..the Westco battery site??? I did!
Below are the results from a GOOGLE SEARCH for AGM MOTORCYCLE BATTERY:
Westco Battery site supplied by MK Batteries
WCP18 Platinum series: $136.95 20 AH/ 340 CCA
12V22 Standard 22AH/ 300 CCA
Interstate batteries:
They show 2 AGM style,
FAYTX24HL Cycle-TronPlus: that's fully charged 21 AH, no CCA listed: $137.95
CYTX24HL-BS Cylce-Tron II is AGM, but says it comes with an ACID PACK, so I'm thinking that you have to actually FILL it with the ACID, and then seal it up?? It's also rated at 21 AH but no CCA listed? $131.95 Retail!
BatteryMart.com has these listed: Cheapest is $92.95 with free ground shipping!
http://www.batterymart.com/c-yamaha-xj1100-battery.html
***********************************8
Batterystuff.com lists one for $88.00 Scorpion brand: 21 AH/ 350 CCA
The above page also shows some Lithium style, but we've discussed this, our charging system doesn't have the Finess to keep from FRYING THESE!!!
BatteriesPlus.com sells an AGM for our bikes: X2-18L with 330 CCA $119.99
http://www.batteriesplus.com/product...wer%c2%ae.aspx
Bikebandit has the Bikemaster one for $104.36 but only 230 CCA !
YuasaBatteries.com shows this model: YTX24HL-BS 21 AH/ 350 CCA ~ $136.00
Ebatteriestogo.com has: Power Source WP50-N18L-A Sealed AGM 22AH/ 350 CCA $105.95 with S&H free.
Happy Shopping. You didn't mention whether this was for your XS11 or your ST, but since you're here, I ASSUMED it was for your XS11, the above links are for the battery that will fit OUR XS11's!
Leave a comment:
