The grinding or what I describe as more of a machine gun sound is what you can expect if your second gear gets as bad as mine was.
The thread you mention is the best to follow that I am aware of although many have chimed in since with tips and support. I used that thread for mine and it went very well.
The washer will move when you pull the countershaft and such to dremel the gears just a matter of moving it one side to the other.
If it can be found the new gear will be very expensive. There are some NOS places that may have them but that will be a lot of work and expense to find. There are a few around who may still have it. I have found older and harder to find parts before but it is not always easy.
Good luck with your bike and fix that issue sooner than later as all it does is ruin your riding time when you could be honking on that mother.
The gears are square cut....in that the dogs and slots are perpendicular, and are also spinning, and so especially in the lower gears, 1st and 2nd, you get/hear/feel that definitive CLUNK when shifting into gears both from sitting still/neutral, as well as just across neutral into 2nd. I've got a copy of an old XS11 commercial which shows the rider starting the bike, and then clunkily shifting it into 1st before taking off! I just search YouTube, and couldn't find it, I've got it on my harddrive on my desktop, I may have to see about re-uploading it....IF Youtube will let me, because of the copyright of the Yamaha and XS11 brand???
