Carb Tuning Success Story: Part Deux
    One thing to note: when the bike idles, it drops below 1k, sounds like it may die, then goes back upto 1100k, stays there for about half a minute, and cycles. Interesting.
    The sync isn't quite right yet.
      +1......any slight idle fluxuation is one of the first tell-tale signs of 'out of sync'.
        • 4015
        I must be close with the sync, as I have just about removed the stumble that showed itself upon take-off. I do still have that cycling effect going on with the idle, and poor gas mileage, plus that choke does not act the way it is supposed to.
        I think I may have a slight rear brake drag, as I sometimes hear a squeal back there when moving the bike (I heard this may be normal), but when I grabbed the disc rotor compared to the front, it was too hot to grab. So, I think that may be a contributing factor to poor mpg's. I do have a rear MC rebuild kit from my 750 that I may use. I'll check into re-building the calipers over the Winter. S/S lines may be on the checklist for Christmas.
        I'm not sure if many of you know, but Scott had installed a threaded plug on the #4 pipe for an O2 sensor he used to tune the bike. I believe he connected it to an air/fuel-rich/lean meter. I am interested in finding a similar piece of equipment and tuning my bike with those results. I'm not sure how accurate it would be, using it on only once cylinder pipe, but it's worth a shot.
        • CRXSi90
          • Jun 2004
          • 400
          • Madison, Wisconsin
          #34
          1: I guess you could get one oxygen sensor and move it from pipe to pipe.
          2: would am exhaust temp sensor be of any use? I think I've heard of people doing that.
          Hats off to you on your persistence here!
          '81 XS11H Venturer - holed up in storage while life happened since 07/08/04
          '81 Kawasaki KE175 enduro - 63 mph of smokey fun, now with collector plates!
            • 3193
            #35
            The whole air/fuel ratio thing is something you do not want to do. that would explain why your initial settings were such a wide range. There is something wrong if you can get the air/idle set at 3/4 turn out. BTDT and it ran like ****e.
            Check this out for synch info.
              • 4015
              I reset the float height to stock settings the other night, and ended-up having to having to adjust each mixture screw a quarter turn lean from prior setting. It's definitely not right, but I'll wait till the Spring to figure out things
                • 4015
                • CaptonZap
                  • Jun 2010
                  • 1748
                  • Denver
                  #38
                  Quit. CZ
                    • 4015
                    Just on the sync. The mixtures or something is still off, if I can't get the choke to act how I know it's supposed to work.
