New Auto Cam Chain Tensioner/Timing Issue?
  • ejhamelin
    • Aug 2013
    • 7
    • Payson, AZ
    I've just replaced my old cam chain tensioner with an auto adjuster from an 83 Venture as my old one was near at the end of it's adjustment. I followed the procedures posted here on the site and all went smoothly. The new cct bolted right up and fits perfectly.
    On the flip side, the bike is now idling low (at around 500rpms), lopes a little at idle and is stumbling, almost like it's loading up, until approximately 3000rpm. Seems to be lacking power now above 3000 as well.
    I'm at 42000 miles, have recently rebuilt the carbs and synced them and have had no running issues whatsoever until I swapped the CCT. Obviously I need to check the timing first, but has anyone had an issue like this or have any thoughts?
    '79 XS11 Standard
    43000 miles, pod filters, 11in rear shocks, auto cct.
  • 650mark
    • Jul 2012
    • 307
    • Mesa, Az.
    was your bike on the centerstand when you did this swap? any new, funny noises coming from the top end?
      • 8962
      I would pop the valve cover and check the cam alignment dots if you noticed a definite loss of power. Chain could have skipped a sprocket tooth when the tensioner was out.
      • James England
        • 3039
        • North of England
        If your OEM CCT was near the end of its adjustment, it means the cam chain is worn and should be replaced. Putting the acct on wouldn't resolve that.
        But, you said the bike ran fine before the swap. My guess is the worn chain has so much slack that it's jumped a tooth when you were doing the job. As has already been said, I'd check the dots on the cams for correct alignment
          • 4015
          I'm praying for you buddy . . .
          • ejhamelin
            • Aug 2013
            • 7
            • Payson, AZ
            Thanks for the advice. I'll pop the valve cover in the morning, take a look and reply.
            '79 XS11 Standard
            • James England
              • 3039
              • North of England
              You may as well check the valve clearances while you have the lid off.....
                • 3374
                You didn't say if it was on the center stand, did you line up the correct mark on the timing wheel, did you line up the correct timing mark by turning the engine clockwise and not turning it counterclockwise even the slightest amount if you over shot the timing mark? Did you rotate the engine by hand a few times after the swap?
                Yeah, you gotta take a look inside now but just curious about the answers to the stuff above...
                2001 ZRX 1200
                1982 Seca 750
                1983 Nighthawk 550
                • Diskman01
                  • Mar 2011
                  • 263
                  • Sioux Falls, SD
                  Ya, I did this upgrade early last summer and ended up being off 1 tooth. No damage done according to my compression tester and butt-dyno. I ended up replacing the chain this past winter anyway. The two dots were starting to wander apart too much for me.
                  Ill bet your chain slipped off the crank one tooth when you installed the tensioner.
                  Good luck!
                  1) Fire up Internet Explorer
                  2) http://www.yahoo.com
                  3) type "www.mapquest.com" into the Yahoo search page.
                  4) go about day as VP managing multi-million dollar financial contracts.
                    +1. If the OEM tensioner was near the end of travel, you need to replace the chain. Don't wait for it to break!
                    • ejhamelin
                      • Aug 2013
                      • 7
                      • Payson, AZ
                      Morning Gentlemen,
                      Worst fears confirmed after taking the cam cover off - it's definitely off a tooth. With the crank (after rotating clockwise a few times) lined up to the 'T', the dots on the cam's are about 1/4 inch to the left of the alignment arrows.
                      I'm going to attempt to correct this in the bike by unbolting the cam sprockets, removing the tensioner, tying the chain up to the frame to keep tension on the intake side of the chain and rotating the cams manually. There's a great post on 'this' procedure by Crazy Steve that I've gone over thoroughly.
                      Any last minute suggestions or pointers? Thanks.
                      '79 XS11 Standard
                        • 4015
                        Yes, follow Steve's post exactly. Make sure wheel is on "C" mark, and hand-rotate the engine clockwise many times to assure cam dots align.
                        • ejhamelin
                          • Aug 2013
                          • 7
                          • Payson, AZ
                          'T' when lining up the dots on the cams and 'C' when reinstalling the tensioner. Correct?
                          '79 XS11 Standard
                            • 5073
                            Dots and arrows at top dead center - the T-mark!
                              • 4015
                              Yes, and "C" when pulling/installing CCT. DO NOT rotate the crank till the CCT is installed, and only then hand-rotate that thing a gazillion times making sure the dots line-up at the "T" mark. Oh yeah, one more thing: when u pull the chain over the sprocket, pull as hard as you can from the back side to make sure there is no slack, and it is indeed on the crank sprocket.
