New Auto Cam Chain Tensioner/Timing Issue?
  • ejhamelin
    • Aug 2013
    • 7
    • Payson, AZ
    Thanks. Don't mean to be a wet noodle here but I only want to do this once:
    AFTER the cct is installed AND rotating the engine a gazillion times, the dots on the cams should be aligned while the crank is at 'T'. Correct? That's where I'm at right now and want to double check before I button it up and go for a ride this fine afternoon.
    Thanks again.
    '79 XS11 Standard
    43000 miles, pod filters, 11in rear shocks, auto cct.
      • 4015
      Yes, absolutely. You should not hear any noise, and it should turn easily.
        • 4015
        I'm kinda surprised you did not have to turn a cam by hand to match them up perfectly.
        • ejhamelin
          • Aug 2013
          • 7
          • Payson, AZ
          Success! Thanks for all the advice - running like it should.
          Until next time..
          '79 XS11 Standard
