Mpg
  • dondons1984
    • Jun 2013
    • 153
    • Walla Walla, Wash.
    Mpg
    SO I decided to see if I was being heavy on the throttle or not. I filled up my tank and reset the trip meter. I have been told we should get around 90 before we have the light come on and then 20 after that. My problem is that at 55 the light came on! what in the world is up with that? Am I out of sync on the carbs? anyone else have this issue? Cause that is a really low number.
    79 SF
    Wow, did I just give advice? should I be doing that?
    1983 GL1100 bored to a 1300 sold
    1976cb750 project gifted to brother
    1979 xs1100s currently working on
    Wanting to have that head turner that makes people shut up!
  • MPittma100
    • Aug 2011
    • 2359
    Typical MPG
    Most of the posts that I have seen on here the guys state that they are getting anywhere from 32-38 MPG. Will vary from load (baggage, number of people, terrain, etc.) and how aggressive you are on the throttle. I am thinking that anything less than those mentioned that there may be some tuning issues that need to be addressed.
    Carb sync should always be checked for accuracy. Also need to know that you have the correct jets in the carbs. I changed the stock main and pilot jets on a 79SF to the stock 78E jets and went from 38 to 35 MPG. Performance gain was worth the lesser fuel mileage. Does your engine perform/run like it should? Verify the amount of fuel used when filling up to see if the low fuel light is accurate.
    MP
    1981 XS1100H Venturer
    K&N Air Filter
    ACCT
    Custom Paint by Deitz
    Geezer Rectifier/Regulator
    Stebel Nautilus Horn
    EBC Front Rotors
    Limie Accent Moves On In 2015
    Mike
    • dondons1984
      • Jun 2013
      • 153
      ok, I am going to go through all of that. I think I am running a little rich so I have to do those adjustments. I did pull the spark plugs
      79 SF
        What did the plugs look like?
        • dondons1984
          • Jun 2013
          • 153
          new like they are getting to much gas
          79 SF
            So they were white? Black? Dry? Wet? Grey? Brown?
            • dondons1984
              • Jun 2013
              • 153
              white and wet
              79 SF
                White means lean Don. If it was running rich they would be black.
                What your saying doesn't seem to make sense.
                You need to try it again. Even the way I ride I get 90 miles out of a tank in town.
                • dondons1984
                  • Jun 2013
                  • 153
                  sorry I get those two mixed up to much. Greg what could the factors be that would kill my MPG?
                  79 SF
                    Sync, riding habits, where you ride. If you sit idling in traffic a lot it'll go down.
                    Look here for reading your plugs.
                    You should.  It is really a lost art that a lot of people don't seem to do anymore.  Even I need a refresher.  Nothing gives you direct info...
                    • tarzan
                      • 1700
                      • Chandler,Az.
                      So, you are getting like 25mpg? I'd have to say something isn't right. Did you check your oil level to see if it is over full? If it is running that rich, and not leaking, the plugs should foul out fairly quickly.
                      80 SG XS1100
                      14 Victory Cross Country
                        I mentioned this in another post a little while ago, have you checked the gap on your plugs? A few years back, another XSive and I took a road trip to Indianapolis leaving from my house on the west side of Cincinnati. We both filled up by my house, and we made it about 56 miles when his bike ran out of gas, bone dry. Had to ride pillion on my bike to get a gas can and some gas and get him back to his bike.
                        He had adjusted the plug gap to try to compensate for some tuning issue he had. When we got to Indy, he reset the plug gaps. On the way home he made the entire trip to his house on the East side of town on one tank.
                          Don,
                          Did you or the P.O. clean the fuel tank and accidentally put the thermistor back in upside down?
                            That's a good point but wouldn't that cause the opposite effect?
                              I can't remember 100% for sure, Greg.
                              It's been too long since I stripped the tank on my '79SF and the thermistor was hosed (rotted away and part of it was missing) so I can't just go out and look. I think the thermistor is supposed to go in pointy-holey side down and if it's pointy-holey side up that'd light off the Fuel light early.
                              Of course if it goes in mounted sideways fore and aft I'm full of beans and should be sacked immediately!
