Bike shut off while riding
  • GLoweVA
    • Jun 2011
    • 1957
    • Virginia Beach, VA.
    With the plug unplugged then you'll get NO voltage to the field coil and no output from the alternator. So, yes, reconnect it back up, ground out the green wire and try again. That should give you max voltage to the field coil and give you a fairly large output on the alt.
    I agree with Steve, this is okay for testing, but I wouldn't leave it like that for too long.
    80G (Green paint(PO idea))
    The Green Monster
    Got him in '04.
    bald tire & borrowing parts
    Scarlet
    Got her in '11
    Ready for the twisties!
    81H (previously CPMaynard's)
    Hugo
    Cold weather ride
    • dschmitta
      • Jul 2010
      • 174
      • Altoona,PA
      Thanks, will do and keep everyone posted. Thanks
      1980 xs1100g
      • dschmitta
        • Jul 2010
        • 174
        • Altoona,PA
        mixed test results
        Well, passed a few tests and failed a few.
        Passed:1. drill bit stuck like glue to alt. cover. 2. checked plug behind fusebox, got no reading from brown or green wire to ground when unplugged. 3. coil disconnected and key off, checked brown wire at regulator plug to ground, no reading, so app. no short there.
        Failed: 1. ohms test on field coil terminals. ohms 5.9, I think should be no more than 3.5. 2. checked brown field coil wire with key on. Voltage was 9.86 and should have been 12 volts, I think. Green wire checked in at 1.12.
        Any ideas or tests u know of greatly appreciated. Thanks
        1980 xs1100g
          You can burn-out bulb filiments doing this...
            I rode my bike with the green wire jumped for 3 months that way due to a bad regulator, didn't burn any bulbs out but I had to refill my battery every 500 miles though. I wouldn't reccomend doing this, it's just for testing purposes.
            • windysolar1
              • Jun 2010
              • 53
              • United Kingdom
              Kaput Regulator
              Kaput Regulator Battery should show 12.6vdc
              The old ones are the best 9000 miles from new and rising
              got a Honda VF1000f 1984 for the summer in the United Kingdom.Wow its Fast,Too fast for Me
              1982 Xj1100J Maxim US Specfast keeps going
              1984 VF1000F Interceptor UK need repair sticking pro link joint, off the road currently but in a newly built 17ft wooden garage, just got to finish it
              • dschmitta
                • Jul 2010
                • 174
                • Altoona,PA
                So Replace regulator/rectifier. This is the two screw one under the fuel tank, correct? Does everyone agree that it seems to be the problem? Thanks for all the help guys, much appreciated
                1980 xs1100g
                • dschmitta
                  • Jul 2010
                  • 174
                  • Altoona,PA
                  found melted plug
                  Took off tank and found stator (the three white, red and black) female end plug coming from the regulator/rectifier had melted through at the red wire. The male end side looks not exactly beautiful either. Should I replace regulator or look for other problem. E/thing worked fine until smal accident and wondering if that did that, Thanks
                  1980 xs1100g
                    I'd try repairing the connections first and see if the charging system works. Then if it works, you can splice in a new connector.
                    • dschmitta
                      • Jul 2010
                      • 174
                      • Altoona,PA
                      I'll do that first. It was still showing good readings with the FSM manual tests. Just wasn't sure if safe to do. Just find new plug harnesses and put together. Think that might work. Thanks for info.
                      1980 xs1100g
                      • dschmitta
                        • Jul 2010
                        • 174
                        • Altoona,PA
                        Definately want new connectors, not just splice and tape, correct?
                        1980 xs1100g
                          Yes, if the regulator works, then put new connectors, until then I would just connect them together temporarily (splice/tape). If it works, you could also hard wire/splice with butt connectors, that will be fine for now but a pain to deal with later.
                          • dschmitta
                            • Jul 2010
                            • 174
                            • Altoona,PA
                            Thanks, will do and let u know.
                            1980 xs1100g
                            • GLoweVA
                              • Jun 2011
                              • 1957
                              If all the components check out and it's time to re-do the connectors,
                              Mikes XS has replacement plug assemblies:
                              http://www.mikesxs.net/products-78.html#products
                              Scroll to near the bottom.
                              The Green Monster
                              Got him in '04.
                              Scarlet
                              Got her in '11
                              Hugo
                              Cold weather ride
                              • dschmitta
                                • Jul 2010
                                • 174
                                • Altoona,PA
                                Thanks for info. Dave
                                1980 xs1100g
