Bike shut off while riding
  • dschmitta
    • Jul 2010
    • 174
    • Altoona,PA
    Originally posted by dschmitta
    Thanks for info. Dave
    Well, Connected all wiring back together, still not charging, starting to think the regulator got fried.
    1980 xs1100g
    • windysolar1
      • Jun 2010
      • 53
      • United Kingdom
      Kaput Regulator
      Before I returned to the UK from my Holiday in Topeka KS riding my Max ,my brothers Road king died at Dover at the crossroads,
      He had to ride Bitch on my Maxim to get the pickup so we could recover it.
      When it got to the workshop it was the regulator and it fried the battery.
      Always regulators they have a hard life and get really Hot.
      The old ones are the best 9000 miles from new and rising
      got a Honda VF1000f 1984 for the summer in the United Kingdom.Wow its Fast,Too fast for Me
      1982 Xj1100J Maxim US Specfast keeps going
      1984 VF1000F Interceptor UK need repair sticking pro link joint, off the road currently but in a newly built 17ft wooden garage, just got to finish it
      • dschmitta
        • Jul 2010
        • 174
        • Altoona,PA
        thanks for info. Dave
        1980 xs1100g
        • dschmitta
          • Jul 2010
          • 174
          • Altoona,PA
          #34
          Put in new regulator, still not charging. going to do green wire test and see if new regulator is good. Not sure how to proceed from here.
          1980 xs1100g
            Did you tap into the green field coil wire and ground it while the bike was running? If the voltage goes up, your regulator is bad, if it doesn't there is probably an issue with the stator.
            • dschmitta
              • Jul 2010
              • 174
              • Altoona,PA
              #36
              just did tap on green wire, grounded and volts did not jump, sounds like stator?
              1980 xs1100g
                Test the stator as described in the FSM if you haven't already.
                • dschmitta
                  • Jul 2010
                  • 174
                  • Altoona,PA
                  #38
                  not sure how. The end of stator wires in behind the fuse panel has no white wire plug. previous owner cut and butt crimped wires together. All are tight and seem to be secure, but I Don't know how to check that. Is there another test or can u check them somehow? Thanks for help. Dave
                  1980 xs1100g
                  • GLoweVA
                    • Jun 2011
                    • 1957
                    • Virginia Beach, VA.
                    #39
                    Could the field coil be bad?
                    Check ohms from the tan(brown) to green wire going to the alternator.
                    Book says it should be 3.5ohms +10%
                    The stator wires (3 of them)(white) should be 0.4ohms +10% to each other.
                    All of them should have a high(open) resistance to ground.
                    Some checks while bike is running:
                    You can measure green to black while the bike is running (connector connected) and it should read about 2 volts at idle and up to 9-11V at higher rpms.
                    Brown to black should start out at battery level and rise up to 14.2 - 14.8V at higher rpms.
                    80G (Green paint(PO idea))
                    The Green Monster
                    Got him in '04.
                    bald tire & borrowing parts
                    Scarlet
                    Got her in '11
                    Ready for the twisties!
                    81H (previously CPMaynard's)
                    Hugo
                    Cold weather ride
                    • GLoweVA
                      • Jun 2011
                      • 1957
                      #40
                      WHAT!! Are you saying that all 3 white wires are crimped together?!?! (in one bundle)
                      The Green Monster
                      Got him in '04.
                      Scarlet
                      Got her in '11
                      Hugo
                      Cold weather ride
                      • dschmitta
                        • Jul 2010
                        • 174
                        • Altoona,PA
                        #41
                        No. Looks like he cut off both sides of plug and went single wire to single wire, just eliminated the plug ends. All wires are put together one at a time, he didn't bundle em(thank god!) They must have worked okay, have had bike 4 years and never had any charge issue until accident. Just don't know how to check butt connected wires. As to field coil, when I check ohms, what setting and should I check from back of plug or unplug and check from prongs? Sorry sounds so stupid, just not sure
                        1980 xs1100g
                        • dschmitta
                          • Jul 2010
                          • 174
                          • Altoona,PA
                          #42
                          u wouldn't happen to have coil/stator assembly for sale in case I need it? Just checking, Thanks, Dave
                          1980 xs1100g
                          • GLoweVA
                            • Jun 2011
                            • 1957
                            #43
                            When checking ohms, check with it unplugged on the prongs (not on the regulator side, but the alt half of the connector)
                            Okay, IF those butt connections are still good, you should be able to check the stator ohms at the regulator/recitfier plug (white wires and not on the regulator side, but the alt half of the connector) Check white to white then white to the other white and that white to the first white. Should be nice and low like about 1ohm or so.
                            I think you posted once that you got about 5ohms on the field coil test, and that should be close enough, but make sure that it's not grounded. In other words check both of them (individually) to ground and hopefully there's nothing.
                            The Green Monster
                            Got him in '04.
                            Scarlet
                            Got her in '11
                            Hugo
                            Cold weather ride
                            • dschmitta
                              • Jul 2010
                              • 174
                              • Altoona,PA
                              #44
                              going out now to test. Thanks, dave
                              1980 xs1100g
                              • howdy_doody
                                • Sep 2002
                                • 15
                                • St. Louis
                                #45
                                Another thread with same problem as mine!!
                                I've got a 1980 1100G and am struggling with charging issues too, I have a separate thread running right now! Interesting that the regulator did not fix the problem, anything new to report?
                                1980 XS1100g, 2nd owner since 1990
