greg actually helped me realize I have 2 stuck/jammed/broken idle screws. Anyone have any extras they wanna get rid of?
1979 xs1100s ignition issue
79 SF
Wow, did I just give advice? should I be doing that?
1983 GL1100 bored to a 1300 sold
1976cb750 project gifted to brother
1979 xs1100s currently working on
Wanting to have that head turner that makes people shut up! -
81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
I did very carefully. I know that I am going to try some other tips just to see if they will work and hold me over till I get other ones.79 SF
Wanting to have that head turner that makes people shut up!Comment
this is what I am talking about all the time guys
79 SF
Looks to actually be in decent shape cosmetically. Even still has the stock airbox, which BTW I would keep on the bike not only for better running performance wise, but makes for tuning ALOT easier having correct vacuum draws for correct diaphram operation of the slides. All has to work together, including the use of stock airbox. From just the looks of the bike, would be an easy one to get back running correctly IMO.this is what I am talking about all the time guys
http://s1274.photobucket.com/user/do...0ec5c.mp4.html81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
cyber repairGreg
Greg you are the best. thank you so much for helping me today and walking me through the whole thing. I wouldnt of known what to do.79 SF
79 SF
In all those pics I see the needle jet/emulsion tube is still in there. That needs to come out because stuff gets in there.
If anyone has a couple idle mixture screws for the early carbs don needs 2. I don't have any that aren't broken.Greg
The area n the pictures is the diaphragm area. while it certainly should be clean if someone just finished cleaning the carbs, that area in particular would not cause the bike to run horribly. What do the float bowl areas look like?Life is what happens while your planning everything else!
78 XS750Comment
He's needing at least one float also.Greg
In the video I thought I saw the engine rock in the frame, or is it just me ?this is what I am talking about all the time guys
http://s1274.photobucket.com/user/do...0ec5c.mp4.html76 XS650 C ROADSTER
80 XS650 G Special II
https://ibb.co/album/icbGgF
80 XS 1100 SG
81 XS 1100LH/SH DARKHORSE
https://tinyurl.com/k6nzvtw
AKA; Don'e, UD, Unca Don'eComment
I did take those off and cleaned. Ha! I cleaned them till 10 at night. I went a little ocd.79 SF
