1979 xs1100s ignition issue
  • dondons1984
    • Jun 2013
    • 153
    • Walla Walla, Wash.
    #61
    I like the pipes don't get me wrong but I'm going to get the carbs tuned and everything set. After that we will see but I think I'm gonna stay with them cause it let's people know I'm there and I have an appointment with the Washington state patrol to make sure they are legal and to have a paper saying they are
    79 SF
    Wow, did I just give advice? should I be doing that?
    1983 GL1100 bored to a 1300 sold
    1976cb750 project gifted to brother
    1979 xs1100s currently working on
    Wanting to have that head turner that makes people shut up!
      Originally posted by dondons1984
      I don't even recognize photobucket anymore. It's stupid now.
      • dondons1984
        • Jun 2013
        • 153
        #63
        Well what do u use?
        79 SF
          Is this where you signed up?
          http://s154.photobucket.com/
          • dondons1984
            • Jun 2013
            • 153
            #65
            Yup that is where I signed up
            79 SF
              Damn thing ain't working right now. The useful idiots must be working on it again.
              • dondons1984
                • Jun 2013
                • 153
                #67
                Lol I just went to it. All it is of is pictures in my truck when I first got it.
                79 SF
                  Damn college boys are trying to "improve" it again. I can't get to any of my $hit!
                    A private space for your group's photos and videos. Share, react, and relive moments together. Available on iOS, Android, and desktop. Free for new sign-ups.
                    • dondons1984
                      • Jun 2013
                      • 153
                      #70
                      OK so got it running fine finally and went for a ride. It started surging and dying all of a sudden. So I came home let it sit and wow that is a lot of oil that is below the air box. Why did it do that? When I would go to shift it would knock a little but kind of surge so I'm actually going to wait till I know what it is.
                      79 SF
                        It sounds like the oil in the crank case is over filled and being blown out.
                        Are you checking the oil while it's sitting on the center stand or the side stand?
                        Also, on another note. What type of oil are you using?
                        • dondons1984
                          • Jun 2013
                          • 153
                          #72
                          The po removed the center stand. I put in 3qts of 10/40. Would that cause all the symptoms I am having?
                          79 SF
                            #73
                            Hey Don,
                            Depends on if you properly drained it before you put in the 3 quarts. If you just pulled the filter bowl then you didn't actually drain all of the oil. There's an oil pan drain bolt just behind the filter cup. You would have left over 2 quarts still in the pan, so with 3 you could now have 5 quarts in there!?
                            Secondly, I think I remember seeing you post about a leaky petcock. If you have a leaky carb float needle valve, then you can get fuel into your engine while parked, which can cause both an overflow as well as a damaging thining of the oil which can damage bearings!
                            Need to get a friend to help hold the bike upright so you can use the viewfinder glass to verify your oil level, but you may need to drain it all of it first, and then refill it with the correct amount.
                            • dondons1984
                              • Jun 2013
                              • 153
                              #74
                              Thanks for the advice. I'm going to drain the oil today and redo my gas lines so I just run off one petcock. Seems to me the left one is causing me issues. So after draining oil sealing off the petcock and draining oil and putting it back in I am going to turn it over and see if it runs smoother.
                              79 SF
                              • GLoweVA
                                • Jun 2011
                                • 1957
                                • Virginia Beach, VA.
                                #75
                                I don't want to sound like chicken little here, but I thought it might be prudent to offer up another possibility.
                                A worst case senario is that you've got blow by past your piston rings, or a small hole in the piston. This will build up pressure in the crankcase and then blow oil out the vent.
                                DAMHIK, but when I burnt a hole in my piston 3-4 years ago, I built up so much pressure it blew the cam cover half moon plug right out from under the valve cover. One of my other symptoms prior to that was some oil blowing thru the vent into the air box.
                                Granted the bike ran like crap on only 3 cylinders and IF I had a compression tester then, I would have found my problem ALOT sooner than I did.
                                I don't mean to scare you, but it may be just as easy to just check the compression number and see where you're at.
                                80G (Green paint(PO idea))
                                The Green Monster
                                Got him in '04.
                                bald tire & borrowing parts
                                Scarlet
                                Got her in '11
                                Ready for the twisties!
                                81H (previously CPMaynard's)
                                Hugo
                                Cold weather ride
