1979 xs1100s ignition issue
  • #91
    greg actually helped me realize I have 2 stuck/jammed/broken idle screws. Anyone have any extras they wanna get rid of?
    79 SF
    Wow, did I just give advice? should I be doing that?
    1983 GL1100 bored to a 1300 sold
    1976cb750 project gifted to brother
    1979 xs1100s currently working on
    Wanting to have that head turner that makes people shut up!
    • #92
      Glad you found the issue as this thread was gittin' long-winded...lol. Did you get the broken tips out also?
      • #93
        I did very carefully. I know that I am going to try some other tips just to see if they will work and hold me over till I get other ones.
        79 SF
        • #94
          this is what I am talking about all the time guys
          http://s1274.photobucket.com/user/do...0ec5c.mp4.html
          79 SF
          • #95
            Looks to actually be in decent shape cosmetically. Even still has the stock airbox, which BTW I would keep on the bike not only for better running performance wise, but makes for tuning ALOT easier having correct vacuum draws for correct diaphram operation of the slides. All has to work together, including the use of stock airbox. From just the looks of the bike, would be an easy one to get back running correctly IMO.
            • #96
              Workin' on it............
              • #97
                Really?..........that IS a 'mean green machine',,,,,Tulsa to WalaWala that quick.
                • #98
                  cyber repair
                  • #99
                    Greg you are the best. thank you so much for helping me today and walking me through the whole thing. I wouldnt of known what to do.
                    79 SF
                    • my oil after I drained it.
                      1st carb
                      second carb
                      3rd carb
                      4th carb
                      They all had some sediment in them that I had to clean out. Greg you are a great help and I am going to stick to motorcycle god
                      79 SF
                      • In all those pics I see the needle jet/emulsion tube is still in there. That needs to come out because stuff gets in there.
                        If anyone has a couple idle mixture screws for the early carbs don needs 2. I don't have any that aren't broken.
                        • The area n the pictures is the diaphragm area. while it certainly should be clean if someone just finished cleaning the carbs, that area in particular would not cause the bike to run horribly. What do the float bowl areas look like?
                          • He's needing at least one float also.
                            • Originally posted by dondons1984 View Post
                              In the video I thought I saw the engine rock in the frame, or is it just me ?
                              76 XS650 C ROADSTER
                              80 XS650 G Special II
                              https://ibb.co/album/icbGgF
                              80 XS 1100 SG
                              81 XS 1100LH/SH DARKHORSE
                              https://tinyurl.com/k6nzvtw
                              AKA; Don'e, UD, Unca Don'e
                              • I did take those off and cleaned. Ha! I cleaned them till 10 at night. I went a little ocd.
                                79 SF
