installed new handle bars and now???
  • troubled1
    • May 2013
    • 20
    • Springfield, OR.
    I installed new drag bars on my xs and now the starter button won't work...is it grounded through the bars? Mine are coated
    80 SG "Black Widder" chop
    • 8796
    Yes it is, best off running a new ground somehow to the R/S switch housing, or if you don't mind sanding the coating off the bar in that area.
    • troubled1
      • May 2013
      • 20
      • Springfield, OR.
      I don't mind...should I sand it off at the risers too?
        Here is a thought, will the bike be garaged or kept outdoors? Anywhere you scrape off the coating, is now bare metal subject to corroding, and causing a future poor ground. Running a wire up to the handle bars through the sheath that the harness wires are in should not be to difficult. Bring it in the switch and put a connector on ti to fit one of the small screws, and it is grounded, now run the other end to one of the screws mounting the reg/rect for a good ground.
        My thought is that in the 81 model (and I thought the 80 model) Mommy Yammie added a ground wire to the starter switch instead of relying on the bars for a ground. Must have realized it was a problematic method of grounding.
          • 8796
          There is a ground wire present at the L/S switch, you'd have to sand there too. I like the wire idea better but your choice.
            Changing out the stock bars and putting on a set of fully adjustable Heli-Bars on my Venturer Ihad to wrap a piece of emory paper around the area where the controls and throttle tube mount and polish the powdercoat off to get a ground. Plus, the throttle tube was dragging on the powdercoat and causing throttle to return slowly.
            • troubled1
              • May 2013
              • 20
              • Springfield, OR.
              Very good advice...I'll run the wire for ground as corrosion could make things difficult. The bike will be garage kept but may ride in the rain a time or two as I live in Oregon. Thanks fellas. I'll let ya know how it goes. Cheers
              • troubled1
                • May 2013
                • 20
                • Springfield, OR.
                Sanded down contact points on the bars and she's alive!!! Thanks again ;-)
