installed new handle bars and now???
  • troubled1
    • May 2013
    • 20
    • Springfield, OR.
    I installed new drag bars on my xs and now the starter button won't work...is it grounded through the bars? Mine are coated
    80 SG "Black Widder" chop
    Yes it is, best off running a new ground somehow to the R/S switch housing, or if you don't mind sanding the coating off the bar in that area.
    • troubled1
      • May 2013
      • 20
      • Springfield, OR.
      I don't mind...should I sand it off at the risers too?
        Here is a thought, will the bike be garaged or kept outdoors? Anywhere you scrape off the coating, is now bare metal subject to corroding, and causing a future poor ground. Running a wire up to the handle bars through the sheath that the harness wires are in should not be to difficult. Bring it in the switch and put a connector on ti to fit one of the small screws, and it is grounded, now run the other end to one of the screws mounting the reg/rect for a good ground.
        My thought is that in the 81 model (and I thought the 80 model) Mommy Yammie added a ground wire to the starter switch instead of relying on the bars for a ground. Must have realized it was a problematic method of grounding.
          There is a ground wire present at the L/S switch, you'd have to sand there too. I like the wire idea better but your choice.
            Changing out the stock bars and putting on a set of fully adjustable Heli-Bars on my Venturer Ihad to wrap a piece of emory paper around the area where the controls and throttle tube mount and polish the powdercoat off to get a ground. Plus, the throttle tube was dragging on the powdercoat and causing throttle to return slowly.
            • troubled1
              • May 2013
              • 20
              • Springfield, OR.
              Very good advice...I'll run the wire for ground as corrosion could make things difficult. The bike will be garage kept but may ride in the rain a time or two as I live in Oregon. Thanks fellas. I'll let ya know how it goes. Cheers
              • troubled1
                • May 2013
                • 20
                • Springfield, OR.
                Sanded down contact points on the bars and she's alive!!! Thanks again ;-)
