Rear Brake Lever Travel?
    • 8962
    Got the m/c and caliper kits today. Noticed that m/c kit does not include the reservoir o-ring. Now I wonder why that does not come in the kit? I mean it is part of the m/c and of course the old one is split. Oh well.
    MP
    None of the kits have that big O-ring, you'll have to match it up down at your local supplier. Someone here may know the correct size. Don't forget to use a little RTV sealer on the new ring to prevent fluid seep.
      Mike,
      I found the o'ring for under the reservoir at my local Ace Hardware. I suggest you do the same. Putting the old one back and calling it good is asking for trouble.
      • MPittma100
        • Aug 2011
        • 2359
        Found one
        Yeah, using the old one was not an option. I have an o-ring kit and was lucky enough to have the right size in it. Good idea about the RTV sealer. I am a little concerned about some minor pitting in the bore nearest the snap ring. I polished the bore with some fine emory cloth, but there is still a little pitting in the bore. I guess I will have to see if it leaks. If so, I will have to find another M/C.
        MP
        1981 XS1100H Venturer
        K&N Air Filter
        ACCT
        Custom Paint by Deitz
        Geezer Rectifier/Regulator
        Stebel Nautilus Horn
        EBC Front Rotors
        Limie Accent Moves On In 2015
        Mike
        • MPittma100
          • Aug 2011
          • 2359
          M/C Rebuild
          Rebuilt and installed the M/C and bled the system. Pedal height came up and I believe that the problem has been solved. Will have to ride it to know for sure.
          Can't decide whether or not to rebuild caliper. I did notice that the pads have been replaced with EBC. Not that many miles on the bike but it is 32 years in service and I do not know if the caliper has been apart before.
          MP
          K&N Air Filter
          ACCT
          EBC Front Rotors
          Mike
