I dont mean to ask dumb questions but the boots arent on backwards by chance are they?
Having a Bear of a time getting the airbox on! Wrong Tubes?
Nate
78 XS11 "Matilda" 2H7 000364
K+N Air Filter
88 Voyager XII
81 XJ650 Maxim
Originally posted by Tat2demon View PostI dont mean to ask dumb questions but the boots arent on backwards by chance are they?
On a side note, the generosity of this site is awesome (aside the helpful info), the member I purchased the tubes from originally saw this post and is sending me another set, and I received an offer from another that said he had some spare airbox parts that he isn't using if I needed. Some real stand up guys on this board and I appreciate the help whole heatedly.79 SF
I know this is an old thread but I wanted to share with you a way to soften up old rubber such as the car boots and air box boots. What I do is I take some Xylol (which is like paint thinner) and some wintergreen oil. You mix a bit of wintergreen oil with the Xylol and soak your rubber parts. In a couple hours your rubber parts will be soft and plyable and smell like a breath mint. Don't however leave the parts in too long because they will swell. If that happens let them sit a couple of days and they will go back to normal. Just a helpful hint.1979 xs1100f
New Fuse Box
Progressive Shocks
Gold Valve Emulator
Dyna Coils
Electronic Flasher
Led Headlight
Led Turn Signals
4 Led Driving Lights
2nd Gear Fix
Auto Cam Tensioner
Digital Dash
Stainless Braided Lines
R6 4 Piston Calipers
Stainless Bolt Kit
Maier Fairing
Dyna Balancing Beads
Spin On Oil Filter
Stebel Nautilus Horn
Plasti Dip Rims
ISO Grips
Originally posted by TheRev View PostI know this is an old thread but I wanted to share with you a way to soften up old rubber such as the car boots and air box boots. What I do is I take some Xylol (which is like paint thinner) and some wintergreen oil. You mix a bit of wintergreen oil with the Xylol and soak your rubber parts. In a couple hours your rubber parts will be soft and plyable and smell like a breath mint. Don't however leave the parts in too long because they will swell. If that happens let them sit a couple of days and they will go back to normal. Just a helpful hint.XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.
Yes, I believe it is. Thanks for the correction.
Originally posted by James England View PostIs Xylol the brand name for a chemical called Xylene, by any chance?1979 xs1100f
New Fuse Box
Progressive Shocks
Gold Valve Emulator
Dyna Coils
Electronic Flasher
Led Headlight
Led Turn Signals
2nd Gear Fix
Auto Cam Tensioner
Digital Dash
Stainless Bolt Kit
Maier Fairing
Spin On Oil Filter
Plasti Dip Rims
ISO Grips
