Having a Bear of a time getting the airbox on! Wrong Tubes?
  • Tat2demon
    • Jun 2012
    • 718
    • Sioux Falls, South Dakota
    I dont mean to ask dumb questions but the boots arent on backwards by chance are they?
    Nate
    78 XS11 "Matilda" 2H7 000364
    K+N Air Filter
    88 Voyager XII
    81 XJ650 Maxim
    • StoneAgeVulture
      • Apr 2013
      • 23
      • Kenosha, Wi.
      Its not a dumb question, it's a question I asked myself a few times, the tubes are on correctly, I took the carbs off and installed them on the airbox outside the bike to be sure of the orientation.
      On a side note, the generosity of this site is awesome (aside the helpful info), the member I purchased the tubes from originally saw this post and is sending me another set, and I received an offer from another that said he had some spare airbox parts that he isn't using if I needed. Some real stand up guys on this board and I appreciate the help whole heatedly.
      79 SF
      • TheRev
        • Jun 2012
        • 235
        • Madison, Wi.
        I know this is an old thread but I wanted to share with you a way to soften up old rubber such as the car boots and air box boots. What I do is I take some Xylol (which is like paint thinner) and some wintergreen oil. You mix a bit of wintergreen oil with the Xylol and soak your rubber parts. In a couple hours your rubber parts will be soft and plyable and smell like a breath mint. Don't however leave the parts in too long because they will swell. If that happens let them sit a couple of days and they will go back to normal. Just a helpful hint.
        1979 xs1100f
        New Fuse Box
        Progressive Shocks
        Gold Valve Emulator
        Dyna Coils
        Electronic Flasher
        Led Headlight
        Led Turn Signals
        4 Led Driving Lights
        2nd Gear Fix
        Auto Cam Tensioner
        Digital Dash
        Stainless Braided Lines
        R6 4 Piston Calipers
        Stainless Bolt Kit
        Maier Fairing
        Dyna Balancing Beads
        Spin On Oil Filter
        Stebel Nautilus Horn
        Plasti Dip Rims
        ISO Grips
        • James England
          • 3039
          • North of England
          Is Xylol the brand name for a chemical called Xylene, by any chance?
          • TheRev
            • Jun 2012
            • 235
            • Madison, Wi.
            Yes, I believe it is. Thanks for the correction.
            1979 xs1100f
            New Fuse Box
            Progressive Shocks
            Gold Valve Emulator
            Dyna Coils
            Electronic Flasher
            Led Headlight
            Led Turn Signals
            2nd Gear Fix
            Auto Cam Tensioner
            Digital Dash
            Stainless Bolt Kit
            Maier Fairing
            Spin On Oil Filter
            Plasti Dip Rims
            ISO Grips
