I decided to clean up my front calipers and take pictures of the process so I could put together a small tutorial... Here is the disassembly and cleaning of my front calipers on my '79F.
Loosen the middle 12mm slide pin bolt then the two outter 14mm bolts.
Slide the assembly off the rotor and remove the philips screw from the back of the caliper. Now the caliper will seperate from the pads and frame.
Take out the little sheet metal shim...
Remove the C clip from the dust boot.
Remove the dust boot and behold the crud. Just brush it away with a nylon brush for the time being...
I was doing both calipers at once so I blocked one with a piece of wood then used the master cylinder to push the other piston out some. Its not a bad idea to do this to both calipers. It should break the stiction between the piston square o-ring inside.
Grab the piston with some vice grips and give it a twist to break it free. Make sure you only grab the end as this part isnt used in the pressure sealing section. At this point I decided to drain the break fluid. Turn the vice grips around and pull the piston out.
At this point you have clear access to the square o-ring. I used a mechanics pic to remove it then proceeded to clean it and the grove behind it.
I used the pic to break loose the chunky stuff then use 120 grit on the upper countersink and OD that was rusty colored. Do not go any deeper than where the square o-ring would begin. That section is clean and machined to proper fit with the piston.
(O-Ring removed)
If you have a dremel with a nylon brush wheel then get it out abd go to town. It worked well and saved some time. I sprayed it out with break cleaner prior to using the dremel. Then do a finish spray after the dremel.
(O-Ring removed)
