Rejet when switching to DynaCoils?!?
    • 2078
    Originally posted by skids
    That is mostly correct. 78 and 79 carbs had vent hoses from the carbies to the nipples on the airbox. The 80 and 81 carbs did not have the vent hoses and the air box nipples were filled with plastic.
    Yep you're correct, forgot about the nipples CRS strikes again !!!
    Late carbs vent the bowls in the intake bell, filter side.
    Thanxs for the reminder.
    • conquest87tsi
      • Jun 2012
      • 190
      • Jackson, Minn.
      Slow progress
      After replacing the seals and reassembling my carbs, my misfire was still there. I believe the issue is with cylinder 3. So I pulled out a set of ‘81 carbs I’ve had for a long time. I have used them to trouble shoot issues in the past. I checked and they have 120 mains and everything else was bone stock for ‘81. The bike is a ‘79. Well it fires right up and synced with like 3 slight adjustments. I took it for a ride and it runs really good to 6k, then screams to redline. Definitely runs better than I can remember on those carbs. I’m just worried about how lean I’m running. Haven’t rode enough to read the plugs yet. I did also confirm leaks on at least 2 of my intake boots. They are Aftermarket replacements that are probably 5 years old. Recommendations on source of replacements this day and age? I’ll dissessmble the 3 & 4 ‘79 Carbs to investigate again I guess while I wait for new boots.
      1979 XS1100 SF
      1979 XS750 SF
      Previous Rides:
      1981 KZ650CSR
      2006 VTX 1300C
      1986 Radian 600
      • conquest87tsi
        • Jun 2012
        • 190
        • Jackson, Minn.
        Swaparo
        I tore down 3 and 4 from the ‘79 set and the emulsion tube on #3 was the 3-2-3-2 hole type, not the 4-4-4-4. If I remember right, the later carbs had the 3-2-3-2. So I put a I believe aftermarket 4-4-4-4 in 3. The 3-2-3-2 tube was a Mikini. So now I am curious what is in the ‘81 set. I guess I’ll pull them tomorrow night.
        1979 XS1100 SF
        1979 XS750 SF
        Previous Rides:
        1981 KZ650CSR
        2006 VTX 1300C
        1986 Radian 600
