Got my new Athena Head Gasket today - question
  • Courtney
    • 542
    • Nanaimo BC Canada
    Got a refund
    They sent me my money immediately via Paypal, and apologized for the waste of time. They said they are going to contact their supplier right away because that obviously looks wrong to them as well. We'll see. Now I'm on the hunt for another head gasket, or should I just use my old one again? It came off fine with no de-lamination or anything. I read one comment where someone said coat it with copper never-seize???? I have a big can of that. Thoughts???
    Bone stock 1980 Special except for the exhaust and crashbars. Oh yeah, and the scabbard for the Winchester Defender.
      • 9981
      If it's not damaged it should be fine. Not anti seize though, it's a spray on coating called "Copper Coat" made by Permatex.
      You just spray it on like spray paint
      • Courtney
        • 542
        • Nanaimo BC Canada
        Thanks BA, this has been QUITE an adventure. OK, cooper coat, looking for it now.
          • 9981
          Just looked it up and either I had the name wrong or they have changed it.
          Here's the stuff I'm talking about....http://www.amazon.com/Permatex-80697.../dp/B000HBNUDQ
            I dunno about the Permatex... that's adhesive, so you'll never reuse that gasket again...
            I've had good luck with plain ol' aluminum-color spray paint. Make sure it uses metal for color (some use polyester flakes), give it a good, wet coat and immediately install it.
            • Courtney
              • 542
              • Nanaimo BC Canada
              This is the condition this head gasket is in. These are extreme closeups so it looks rough, but these areas seem to be along the edges of the head area, so probably corrosion over the years. The main cylinder seals are fine which will hold the compression. I"m thinking it's good enough to use if I use the Copper Coat by Permatex??? Or some good layers of alum. spray paint?
                Wipe it off with some lacquer thinner, spray the snot out of it with aluminum paint, and I'd use some high-heat silicon sealer around the cam chain opening to prevent leaks
                  • 9981
                  I would think the paint would bubble and cause problems because it's not designed to withstand the heat.
                  Did another search and this is what I remember using. I don't know where I got the Permatex Idea but I have used that before and it really doesn't stick.
                  http://www.oreillyauto.com/site/c/de...-1_-1&pt=N0488
                  • WSL91
                    • Feb 2012
                    • 427
                    • Quad Cities, IL
                    Aluminum paint is also used by the tractor guys on head gaskets. I picked up some brand of head gasket sealer that appears to be fine ground copper in the solution. Any of them will work, clean the head and jugs well. The missing rings are indeed "fire rings"
                    1970? Honda Z50... gone
                    1974 Honda CB200... gone
                    2008 Honda VTX 1800F
                    http://www.johnsoldiron.com
                    • Courtney
                      • 542
                      • Nanaimo BC Canada
                      That stuff looks fine to use BA, went to their site and found this info.
                        I would think the paint would bubble and cause problems because it's not designed to withstand the heat..
                        I learned that trick years ago when using steel shim head gaskets (the thin steel gaskets were worth a few tenths of compression ratio) and never had a failure if I used the paint.... They tended to leak oil/water otherwise...
                        • Courtney
                          • 542
                          • Nanaimo BC Canada
                          So Steve, do any paint brands come to mind when you say cheap with aluminum particles??? I don't want to buy the wrong crap. Maybe I should just go with the permatex copper stuff, cause it says it fills imperfections, is for head gaskets to cylinders etc. Seems like the right product???
                            Just make sure the listed pigment is aluminum powder; I've used everything from $10 per can VHT High-heat to .99 per can no-brand paint... never had a problem with any of them, and the gaskets release easily when you pull the head...
                            And when I say a wet coat, I mean dripping...
                              • 9981
                              Yeah, that's when I learned about Copper Coat too.
                              Ha ha, you gotta look long and hard to find a steel head gasket these days.
                                Haven't seen one in years, but they were a 'hot trick' 'back in the day'...
                                They were really thin too; IIRC, the ones I was using (on a big-inch FE Ford motor) were only .015" thick (compared to about .060" for the regular head gaskets) and came out pretty much dead flat when you removed the head...
