Got my new Athena Head Gasket today - question
  • GLoweVA
    • Jun 2011
    • 1957
    • Virginia Beach, VA.
    I will also add to make sure you clean up the seating surfaces before reassembly.
    Pulling that old gasket off has definitely left some of the old gasket on the head and jugs. scrap all that crap off then the 'reused' 'painted' gasket will have a smooth surface to seal on.
    I didn't do this and I think it's why mine failed and I ended up with two holed pistons.
    80G (Green paint(PO idea))
    The Green Monster
    Got him in '04.
    bald tire & borrowing parts
    Scarlet
    Got her in '11
    Ready for the twisties!
    81H (previously CPMaynard's)
    Hugo
    Cold weather ride
    • Courtney
      • 542
      • Nanaimo BC Canada
      Absolutely true, you can see the little bits of the old gasket on the cylinder top and on the head, so those will be coming off with a good scrub from a 3M scotchbrite pad. I'm going to buy the Permatex Copper Coat, I like their def. of it on their website; specifically for head gaskets and fills in small imperfections. Sounds like just the ticket.
      Bone stock 1980 Special except for the exhaust and crashbars. Oh yeah, and the scabbard for the Winchester Defender.
      • ViperRon
        • Feb 2011
        • 1062
        • Woodstock, VA
        That permatex copper seal is great stuff but i suggest you just put a thin smear on the gasket part because it bonds like a weld after heat hits it. If you plan on never taking it apart then put a lot.
        Rodan
        1980 G Silverbird
        1198 Overbore kit
        Grizzly 660 ACCT
        Barnett Clutch Springs
        R1 Clutch Fiber Plates
        122.5 Main Jets
        ACCT Mod
        Mac 4-2 Flare Tips
        Antivibe Bar ends
        Rear trunk add-on
        • Courtney
          • 542
          • Nanaimo BC Canada
          #34
          Maybe the K&W brand of copper coat is less adhesive? I don't really want it to stick, I want it to just take up any imperfections etc.
          • Courtney
            • 542
            • Nanaimo BC Canada
            #35
            UPATE -Got my new headgasket today
            The company from UK that originally sent me the bad head gasket sent me a new one today that has the correct steel inserts around the cylinders. They sent it rush, at no cost to me, and no charge for the gasket itself. I think that is pretty darn good service to make up for a mistake! Too bad I put the old one on 3 days ago. :-/ They are called bitzforbikes on Ebay.
            • GLoweVA
              • Jun 2011
              • 1957
              #36
              Now you have a spare ready to go next time you decide to pull your head off.
              The Green Monster
              Got him in '04.
              Scarlet
              Got her in '11
              Hugo
              Cold weather ride
                • 3193
                #37
                Or when he has to replace it if the current gasket is not properly made. Wonder why the replacement was sent so quickly if the original was good.
                  He put in the original.. as in the ORIGINAL head gasket that was there when he took the bike apart, not the original new gasket.
                  I've re-used the old head gaskets a lot if they haven't de-laminated. Never had a problem leaking, and after you torque them, you don't have to do it again after a heat cycle. They're already pre "Squished". I check them again anyway, but have never had any loose.
                  • Courtney
                    • 542
                    • Nanaimo BC Canada
                    #39
                    TRBIG is right, I re-used the original gasket because the first one they sent me was a dud with NO metal sealing rings around the cylinder holes in it. Weird. Anyway, they refunded me all my money at the time, and this new one with the correct metal rings in it arrived yesterday at no charge from the UK. Pretty good service I'd say, as well as an apology. Sorry if I didn't make that clear enough.
                      • 3193
                      #40
                      Most likely I did not re-read the thread before replying . Good for the seller to make good on that.
