Plugs looks good.........you have some sort of secondary ignition issues, pick-up coil wires, etc. The other thing is, have you checked the advance unit under that left cover to make sure it EASILY moves by hand.....as in floppy loose. If it's not, your gonna have to remove it and clean the whole advance unit of any rust. Just throwin' out ideas, and that IS a biggie to get these to run smooth under load.
First time working on multiple carbs on the Trashboat
Without going back and reading all the posts I have a couple of thoughts here. Not trying to bust you or anything but I think the synch and the idle position screw are off their proper spot.
Was the gas cap vent not working during the synch? Video shows the thing with the tank on backwards. If the synch was done before the vent was fixed I would suspect the synch is off.
Did you keep an even temperature while doing the synch? I notice on the video that there was no fan present, so if that was the case when synching the carbs it would have gotten increasingly hotter. This would make a decent synch next to impossible. I have even had issues with using too strong of a fan and cooling the center two cylinders more than the outer ones. Used a leaf blower without any diversion on that one.
Were the carbs preset before installation? By that I mean did you use the bread tie method or the three hole butterfly method before installing them? If so, how far was the idle position screw turned in from the stop. If it is too far off the stop position the carbs could be set to where "they think" they are halfways open.
One can set the idle and synch in this position and then it will run like crap. I personally made this mistake "no DAMHIKIJD".
Was the synch done before or after the tight throttle cable was noticed. It may have been pulling a wee bit during the synch and threw it off a little.
I think it was Nate who asked if you set the idle air with the morgan carbtune, but I think I recall you mentioning that you did it by ear, but as pilots play a bigger part than just during idle I wonder if that could be out a bit.
Are all the vents to the carb free and clear?
Did you take the carb bodies off the rail when you cleaned them?
Is your choke linkage still in place with all it various springs and balls etc and were they cleaned as well?
Did you spray around the carb system with water or propane or anything else to detect leaks or just order new carb boots and install them?
Is your timing spot on?
Have you checked the valve shims and compression etc?
Like I say, just a couple of thoughts and questions that I ask in case you missed something or it jogs another members memory. Every once in a while a "Dumb" question (like mine) asked by another member will get the whole groups thought processes flowing. Good luck!2-79 XS1100 SF
2-78 XS1100 E Best bike Ever
Originally posted by sparkfly88 View PostFound myself some bad pickup wires!
Well I did the fix using the repair tip.
I soldered and heatshrinked it.
Still didn't fix it.
I did adjust the spark advance to make it run better. Seems all the way counter clockwise makes it run pretty dang smooth.
Still likes to hit a wall at 5-6k rpm.
Turning it to prime helps ( I think) but not much.
The throttle is still sensitive, I only have an inch or so of travel to work the whole bike.....79F
"Excelsior"
Honda gl1100 handlebar
Vetter IV fairing with speaker system
OE headers,Jardine slipons
Hid headlight 6000k
Stock jets
Shinko 712 F & R
Oe hardbags and luggage rack
TC fuse block
K&n filter with oe airbox
Raptor 660 Acct
Installed cam chain auto tensioner, kept petcocks at prime position and I got the RPMs at the highest they have ever been, and I actually think I hit the rev limiter!79F
"Excelsior"
Hid headlight 6000k
Stock jets
Shinko 712 F & R
TC fuse block
Raptor 660 Acct
Originally posted by sparkfly88 View PostInstalled cam chain auto tensioner, kept petcocks at prime position and I got the RPMs at the highest they have ever been, and I actually think I hit the rev limiter!81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.
Originally posted by sparkfly88 View PostWell I did the fix using the repair tip.
The throttle is still sensitive, I only have an inch or so of travel to work the whole bike.....81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.
Well, under load, same thing, hits a wall at 5K rpm.
I decided on my way back home today that I'm out of options in my mind...
I dropped it off at a local bike shop to pray they can figure it out79F
"Excelsior"
Hid headlight 6000k
Stock jets
Shinko 712 F & R
TC fuse block
Raptor 660 Acct
Did you check that mechanical advance unit under the left ignition cover. The weights and springs can freeze up from sitting, keeping the timing from fully advancing at higher RPM, JAT2H7 (79)
3H3
You need to unclip those wires and check them all better. If one is broken others most likely are too.Nathan
Originally posted by natemoen View PostYou need to unclip those wires and check them all better. If one is broken others most likely are too.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.
