Aluminium Filler?
  • Steveh
    • Jan 2013
    • 7
    • Adelaide, South Australia, Australia
    Aluminium Filler?
    I want to fill some bad pitting in the polished part of my wheels.
    Does anyone know of a putty type of filler that can be polished after it hardens? (eg. Lab Metal, Davcon)
    Has anyone used a low temperture melting aluminium filler rod on wheels? (eg.Muggyweld Super Alloy 1 or 5)
    Has anyone tig welded on wheels?
    Im only talking about cosmetic repairs here.
    Is there anything to fill these pits and can be polished to look at least better than just holes?
    I dont want to paint the polished part of the rims.
    81 RH
    • 5058
    I would be afraid to weld on the wheels. Heat stress. I would think that temperature to melt aluminum to aluminum could be a bad thing, but hey I have been wrong before!
      Originally posted by Steveh
      I want to fill some bad pitting in the polished part of my wheels. - - -
      Hi Steve,
      I don't see filling the pits and re-polishing looking anything but effin' 'orrible.
      If the pits are deep enough to TIG weld the rim is scrap anyway.
      Two things to try:-
      1) Bead blast the polished areas to disguise the aluminium acne.
      2) Find a big enough lathe and remove a skim cut off the surface to get back to new metal.
      • mack
        • 2411
        • Ontario, Canada
        Hi
        Crazy Steve turned me onto this product. I haven't tried it yet but sounds like what your looking for. Looks like super alloy 5 is the right one.
        Find high-quality welding supplies at our online welding store. Shop products that offer reliability, efficiency, and ease, ready to meet your welding needs.
        __________________
        mack
        79 XS 1100 SF Special
        HERMES
        original owner
        81 XS 1100 LH MNS
        SPICA
        78 XS 11E
        IOTA
        https://youtu.be/wB5Jfbp6SUc
        https://youtu.be/RaI3WYHSuWA
        Frankford, Ont, Canada
        613-398-6186
        • donebysunday
          • Oct 2012
          • 1737
          • New Berlin, Wi.
          I just wonder if rubbing tin foil on that pitting would make it look OK temporarily ?
          76 XS650 C ROADSTER
          80 XS650 G Special II
          https://ibb.co/album/icbGgF
          80 XS 1100 SG
          81 XS 1100LH/SH DARKHORSE
          https://tinyurl.com/k6nzvtw
          AKA; Don'e, UD, Unca Don'e
            Hey Fred,
            I was thinking more along the same lines as your last comment, get a flap grinder with a fine grit and grind away the surface aluminum to get a smooth finish, then he should be able to get a better surface for polishing. These rims are quite thick, so a few thousandths off shouldn't affect their durability and strength.
            • rambler Shawn
              • May 2012
              • 36
              • Qualicum Beach, B.C., Canada
              I've tig'ed stuff like this daily. Hot and fast to reduce the HAZ (Heat affected zone). If you or someone you know is decent with a torch, have at her. Then machine the surface for the best results.
              79F cafe
              • BigRed
                • Mar 2010
                • 265
                • Ottawa, Ontario, Canada
                I don't know what alloy or heat treatment was used on our rims, but welding aluminum can wreck the heat treatment, and you can lose about two thirds of the strength in the alloy. For example (this is from memory, so don't use these numbers to build a spacecraft), 6061 alloy with T6 heat treatment has a yield strength around 45 ksi, and that drops to around 14 ksi in the heat affected zone if you weld it.
                I would opt for filler and paint over taking the chance on welding. Your wheels would be most stressed when you're in a bad situation already... I wouldn't want it to get any worse.
                '80 SG with motor from a '82 XJ
                  • 2076
                  Like Fred suggests, if the wheel or wheels are pitted badly they are already compromised. Got any pics ?
                  IMHO you may have more time and materials in a fix than securing a good used one or two form Andreas Weiss or here's one of many on ebay:
                  • XS1100_OEM4ME
                    • Mar 2009
                    • 1619
                    • Fort Myers, Florida
                    Dealer
                    Check with your local high end car dealer, they will have a person that repaires road rash on their alum wheels, they can fix yours if you like or sell you the filler so you can fix yourself. It is a two part filler and made just for your needs, or just order some here:
                    1980 XS1100 Special
                    1990 V Max
                    1982 KZ750 LTD Twin
                    1974 CB750-Four
                    Past/pres Car's
                    • CaptonZap
                      • Jun 2010
                      • 1748
                      • Denver
                      Check me if I'm wrong, but Steveh wanted something that would polish up like bare aluminum.
                      The stuff you pointed out is for the painted rims that seem to be the norm on newer cars.
                      I think his best bet would be to find a used rim that wasn't pitted, as all the processes suggested so far are long on labor and cost.
                      The old wet blanket, CZ
                      • Rasputin
                        • 3189
                        • Lacombe, Alberta, Canada
                        You have to remember that he is in Australia so the simple act of getting one shipped is very costly if it comes from here. Thus the need for a better/cheaper fix. I have rims I could send for free but the shipping and time would be prohibitive. I think parts are not as easily come by down under as they are here. I could be wrong (again) but that's my take on it.
                        2-79 XS1100 SF
                        2-78 XS1100 E Best bike Ever
                        • Steveh
                          • Jan 2013
                          • 7
                          Thanks Ras
                          81 RH
                          • XS1100_OEM4ME
                            • Mar 2009
                            • 1619
                            +1, the best fix would be replace the wheels with real nice ones if he can find cheap. The paint, if you want to call it that, for the wheels has come a long way as seen here:
                            true, it looks best when sprayed on, but if he polishes the wheels 1st, fills the pits that show, then touches up with the silver coat, it should look good, not perfect, but good.
                            As to the shipping, the sight I sent is in the UK and offers free worldwide shipping to Australia
                            1980 XS1100 Special
                            1990 V Max
                            1982 KZ750 LTD Twin
                            1974 CB750-Four
                            Past/pres Car's
                            • XS1100_OEM4ME
                              • Mar 2009
                              • 1619
                              Pits
                              Pits are an easy fix with this stuff, If the wheels are so bad that this won't help, they need replaced for a lot of reasons, some safty related, if not, then LOOKS are an easy fix this way
                              1980 XS1100 Special
                              1990 V Max
                              1982 KZ750 LTD Twin
                              1974 CB750-Four
                              Past/pres Car's
