Tire Size Options
  • captjanes
    • Jun 2012
    • 72
    • Newfoundland, Canada
    Tire Size Options
    not sure if this is the place to post this. on my bike now are front- 100/90-19 rear- 130/90-16.. what is the widest tire that i can put on the rear so i got alittle more rubber for turns. i was thinking maybe 150?? i dont wanna change rims.
    1980 Yamaha XS1100LG Midnight Special
      The front you can get a 110/90/19 on with no problems but with the shaft drive in the rear the 130/90/16 is about all you can get in there without modding the shaft tube or converting to chain drive. The 140/90/16 will go on there but the sidewall will rub in the corners on the left side.
        I was talking to somebody who knows way more about this than me just recently. What he taught me was that if you're talking only about going around corners, you want the smallest tires that will fit and ideally the front and rear tires should be the same size.
        Obviously, there are more considerations than just going around corners as Crazy Steve pointed out to me when I was recommending a small rear tire. There are matters like weight and horsepower to consider. In the case of the XS1100 Special I believe the most important factor was how it looked. I believe if you could actually get a 150 wide tire in there, it would actually degrade your performance, at least in getting around corners.
        The first number -130- is the width of the tire in millimeters. If you measure how much space you have, you may learn 130 is about as wide as you can go.
          not sure if this is the place to post this. on my bike now are front- 100/90-19 rear- 130/90-16.. what is the widest tire that i can put on the rear so i got a little more rubber for turns. i was thinking maybe 150?? i dont wanna change rims.
          Hi Mitch,
          those tire sizes are just about as big as will fit.
          The front will go to 110/90-19 if you are OK with a 1/32" clearance on the fender.
          Anything bigger than a stock 130/90-16 on the rear will rub on the swingarm.
          BTW, there ain't no wider rimmed wheels you could change to anyway.
          • XS11UFO
            • May 2012
            • 74
            • Palatka, Fla.
            Tire size?
            After reading this thread, I was really comfortable ordering 2 tires. 130/90-16 rear and 100/90-19 front. The tires came in so I pulled the wheels, BUT - the rear is a 130/90-17? WTH? The last tire was put on by a shop, I never checked.
            Is it possible I have a 17' wheel? Or do I put on the 16?
            Scott
            1978 R100S BMW
              Your signature shows you to have a 79 F. An F is a standard and is equipped from the factory with a 17" tube type tire.
              • XS11UFO
                • May 2012
                • 74
                • Palatka, Fla.
                I'm an idiot
                I was afraid of that, DOH!
                Scott
                1978 R100S BMW
                  Then options on 17" tires is pretty slim. It's not a real popular size. Where did you order them from?
                  You may be able to contact them and swap it out.
                    • 4015
                    Greg- I thought just the E had tubed tires???
                      78, 79, and 80 standards had tube type 17" rear tires. The only standard that came with a tubeless rear tire was the 81 Venturer.
                      There may have been some late 80's but I'm not sure.
                      The tube type rear wheels are fairly easy to convert to tubeless. The bead locks needed to be removed and the holes for them sealed up.
                      • ViperRon
                        • Feb 2011
                        • 1062
                        • Woodstock, VA
                        My 1980 G made in May has a 17 inch tubeless rear so it was at least middle of the year.
                        Rodan
                        1980 G Silverbird
                        1198 Overbore kit
                        Grizzly 660 ACCT
                        Barnett Clutch Springs
                        R1 Clutch Fiber Plates
                        122.5 Main Jets
                        ACCT Mod
                        Mac 4-2 Flare Tips
                        Antivibe Bar ends
                        Rear trunk add-on
                          Like I said I'm not sure about all the 80's. A lot of people have swapped them out over the years and put Venturer wheels on them also.
                          • WMarshy
                            • Apr 2009
                            • 2402
                            • Mexico NY
                            This past spring I put on a new front tire and switched to a 110/90-19. I will be going back to the 100/90 next tire for sure. Reasons are because any increase in handling is negligible and unnoticed. Second, the added weight of the larger tire was definetly noticeable an seemed to have a dramatic impact on the flick-ability of the front end (i.e. More gyroscopic effect and harder to turn).
                            '79 XS11 F
                            Stock except K&N
                            '79 XS11 SF
                            Stock, no title.
                            '84 Chevy K-10 "Big Blue"
                              Funny, my experience was exactly the opposite.
