Good (cheaper) source for float needles
  • 81xsproject
    • 3185
    • Fortuna, CA
    Trying to keep costs down for my carb customers and noticed that the damn float needles (80's) seem like they are more expensive every time I go to buy them. Was wondering if anyone had found any good sources (like the boats.net shaft seals). Right now it is looking like Mikes is the cheapest at $5 ea. TIA, Jessie
    '81 XS1100 SH
    Sep. 12th 2015
    RIP
    • 8061
    What is the OEM part number for the needle?
    • 81xsproject
      • 3185
      • Fortuna, CA
      Don't know. YAM site only lists it as a set.
      '81 XS1100 SH
      Sep. 12th 2015
      RIP
        • 8061
        That makes it very difficult to search.
        • Petersg_99
          • Apr 2012
          • 184
          • Phoenix, AZ.
          Mikes XS shows
          "Float Needle with clip Mikuni BS34 CV carbs" for $5.00
          http://www.mikesxs.net/product/48-5014.html
          Shipping is a pain unless you're buying a bunch...
          Guy
          1980 XS1100G - Frankenstein - resurrected from the impound lot
          1991 Suzuki GS500E (not running yet)
          2003 Burgman AN400 - Blue Belle
          2005 Burgman AN400 - Silver Belle
          • Aches n Pains
            • 349
            • Reston, Va.
            Jessie,
            Is it just an old wives tale that you need to replace the needle and the seat together?
            Thanks
            1995 KZ100P
            Pods, jets, pipes, cam adjuster, oil cooler
            1977 Ironhead - custom build
            Hot engine, custom frame, KZ front and rear, high torque starter, alternator conversion, Progressive shocks, Thunderheart wiring, Dyna ignition, oil cooler, Dakota Digital instruments, etc.
            Sold all my XS's to Eastcoaster but still love to keep up with you guys. This is the best cycle forum on the web.
              • 7817
              The viton tip needles can be replaced without replacing the seat, if the seat is still in good condition. If you have the brass needles and seats, it's best to replace both. You CAN "clean up" the seat, but you need to know what you are trying to do, and have the proper, fine grit paper/stone to do it. JMHO
                I have cleaned the seats before using Eagle 1 on a Qtip. It worked for me. You do need to be sure that you leave no fibers. Maybe this could affect the float "height" adjustment if you got too agressive and enlarged the hole a bit, I don't know. It also works well for the seat in the standard petcocks.
                  I want somewhere to get the seats for a decent price!
                  • Yard Dogg
                    • Mar 2010
                    • 884
                    • Tri-Cities, Wa
                    I can't even remove my seats, any suggestions? I'm going to replace them with he needles. The cheapest I can find is Mikes XS as well.
                      Yeah I had that problem too, the seats on my spare carbs were coroded and had some pits it wouldn't come out. I just grabbed them with a pliers and squeezed and twisted. I crushed them but they came out.
                        Yeah, but you indicated cheap and free is even better.
                          If I could find free I would be ok with that, but cheap is acceptable as well!
                            • 8061
                            Float Needle - 6pk. $23.69
                            The part numbers are listed, so you may continue the search for a lower price.
                            • 81xsproject
                              • 3185
                              • Fortuna, CA
                              Yep, those are cheap because they are brass needles for early 11's. Again this is for the 80's carbs. I appreciate all the help.
                              Why bother looking for seats? Why not just make the investment and go XV920's? Then, you too will only need to replace needles in the future (still cheaper).
                              '81 XS1100 SH
                              Sep. 12th 2015
                              RIP
