Main Jets for 1981 XS1100H
    Originally posted by Schming
    Hey bud your tank came stock with self adhering emblems no screws or mounting tabs
    81 Special and Venturer along with the XJ(Maxim) came new with the wrinkle finish black valve cover.
      FWIW, I've never removed the 'peen' from the throttle plate screws when removing them. I've only had one break off, and that one broke without even loosening up. They will turn out a bit hard, but not that hard and I've even reused them with no issues. I do put some locktite on when reinstalling though...
        I don't know, maybe a little screw bouncing around in the combustion chamber could clean out the carbon build-up. (kidding)
        • mmatches1
          • Sep 2012
          • 121
          • Alberta, Canada
          #34
          I thought that the guy got carried away with the spray paint but it seems like it is more original than I thought. I thought that my buckhorn handlebars were added but found out that they were standard on some H models. I have learned allot about this bike thanks to the forum.
          81H Venture - hope to ride summer 2013
          79F Cafe Racer at Some Point;
          68 CB175 Sloper - Cafe Racer
          74 KZ400 - Restoration project nightmare
          62 BSA Super Rocket - In Pieces
          72 CB100 Super Sport - Not super or sporty but fun
          • mmatches1
            • Sep 2012
            • 121
            • Alberta, Canada
            #35
            Butterfly Seals
            Just realized that I soaked the carb units in cleaner and may have compromised the butterfly seals. I am going to swap them out. Can I assume that there are 8 seals per carb? The parts diagram shows only one.
              • 2104
              2 shaft seals per carb, 8 per bank of 4 carbs
              • mmatches1
                • Sep 2012
                • 121
                • Alberta, Canada
                #37
                Butterfly screw blues
                I manged to release one butterfly but bogged down on the second. Screw stripped even after filing the underside. I knew it wouldn't be easy.
