Gasket
  • mack
    • 2411
    • Ontario, Canada
    Gasket
    When I took the jugs off the upper case, I noticed the gasket was pretty thick in comparison with else where on the motor. Anyone know what the spec was on this gasket. I have an old set around here someplace but I don't remember it being any thicker than any of the others. Seems to me to be a fairly important detail.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    Don't even need a gasket between the jugs and case. Use anaerobic gasket maker and be done.
    • ViperRon
      • Feb 2011
      • 1062
      • Woodstock, VA
      The original gasket and the supplied one in the Yamaha kits are thinner than the side cover gaskets. Its like double thickness paper and tuff not as compressable as the side cover gaskets. Now when people mill down the heads and there is not enough clearance between pistons valves and head then a thicker gasket needs to be used somewhere to get proper clearance. It's a lot easier to put a thick gasket between juggs and engine than to find a head gasket that is thicker. A thick gasket does not guarentee the head has been milled its just something to look for.
      I agree that putting down a coat of anaerobic gasket maker will seal it but suggest that you also use the O rings they go a long way in preventing leaks. For god sake do not use something like Indian head gasket sealer cause you will have a **** of a time ever getting it appart.
      Rodan
      1980 G Silverbird
      1198 Overbore kit
      Grizzly 660 ACCT
      Barnett Clutch Springs
      R1 Clutch Fiber Plates
      122.5 Main Jets
      ACCT Mod
      Mac 4-2 Flare Tips
      Antivibe Bar ends
      Rear trunk add-on
      • mack
        • 2411
        • Ontario, Canada
        I doubt this
        head has been milled. The first owner was a chick and she only put a 3K on it. The second was a guy who didn't even know there was a kick start lever under the battery bracket and was using a set of vice grips instead. I have a sheet of "Fel-Pro" Rubber fiber 1/16 inch thick, that I'm going to use for the middle drive gear housing gasket. But I'm thinking it might be too thick for the jug, upper case location.
        mack
        HERMES
        original owner
        81 XS 1100 LH MNS
        SPICA
        78 XS 11E
        IOTA
        613-398-6186
        • TADracer
          • May 2006
          • 1417
          • Kenner, Louisiana USA
          I checked deck height on my motor before removing the jugs for the first time and it measured only .005" at the edge of the piston.
          Also, a stock head gasket after it is compressed should be around .050". So if your head is milled and you are putting everything back together you might want to double check piston to valve clearances after you torque the head down.
          Mike Giroir
          79 XS-1100 Special
          • XS1100_OEM4ME
            • Mar 2009
            • 1619
            • Fort Myers, Florida
            Rubber
            Don't think I would use rubber fiber here.
            Unless some mods, as others here have mentioned, have been done, I would just spend the $20 or so and go OEM like this one
            http://www.ebay.com/itm/YAMAHA-XS110...72d05b&vxp=mtr
            1980 XS1100 Special
            1990 V Max
            1982 KZ750 LTD Twin
            1974 CB750-Four
            Past/pres Car's
            • Rasputin
              • 3192
              • Lacombe, Alberta, Canada
              I have an Athena base gasket here that is brand new and it measures out at 0.55 mm. Hope that helps.
              2-79 XS1100 SF
              2-78 XS1100 E Best bike Ever
                Hi Mack,
                I need an excuse to tidy my garage shelf I think i have the gasket you need i will lokok to morrow.
                  Hi Mack,
                  FOUND IT. second place I looked so no need to tidy the shelf
                  2 inches of snow and temps dropping so no incentive to stay in the unheated garage. Put the battery tender on the bike.
                  Let me know when you are through this way or do i need to mail it?.
