When I took the jugs off the upper case, I noticed the gasket was pretty thick in comparison with else where on the motor. Anyone know what the spec was on this gasket. I have an old set around here someplace but I don't remember it being any thicker than any of the others. Seems to me to be a fairly important detail.
Gasket
Gasket
mack
79 XS 1100 SF Special
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
https://youtu.be/wB5Jfbp6SUc
https://youtu.be/RaI3WYHSuWA
Frankford, Ont, Canada
613-398-6186Tags: None -
Don't even need a gasket between the jugs and case. Use anaerobic gasket maker and be done.Nathan
Theodore Roosevelt -
The original gasket and the supplied one in the Yamaha kits are thinner than the side cover gaskets. Its like double thickness paper and tuff not as compressable as the side cover gaskets. Now when people mill down the heads and there is not enough clearance between pistons valves and head then a thicker gasket needs to be used somewhere to get proper clearance. It's a lot easier to put a thick gasket between juggs and engine than to find a head gasket that is thicker. A thick gasket does not guarentee the head has been milled its just something to look for.
I agree that putting down a coat of anaerobic gasket maker will seal it but suggest that you also use the O rings they go a long way in preventing leaks. For god sake do not use something like Indian head gasket sealer cause you will have a **** of a time ever getting it appart.To fix the problem one should not make more assumptions than the minimum needed.
Rodan
1980 G Silverbird
1198 Overbore kit
Grizzly 660 ACCT
Barnett Clutch Springs
R1 Clutch Fiber Plates
122.5 Main Jets
ACCT Mod
Mac 4-2 Flare Tips
Antivibe Bar ends
Rear trunk add-on
http://s1184.photobucket.com/albums/z329/viperron1/Comment
I doubt this
head has been milled. The first owner was a chick and she only put a 3K on it. The second was a guy who didn't even know there was a kick start lever under the battery bracket and was using a set of vice grips instead. I have a sheet of "Fel-Pro" Rubber fiber 1/16 inch thick, that I'm going to use for the middle drive gear housing gasket. But I'm thinking it might be too thick for the jug, upper case location.mack
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
613-398-6186Comment
I checked deck height on my motor before removing the jugs for the first time and it measured only .005" at the edge of the piston.
Also, a stock head gasket after it is compressed should be around .050". So if your head is milled and you are putting everything back together you might want to double check piston to valve clearances after you torque the head down.Mike Giroir
79 XS-1100 Special
Once you un-can a can of worms, the only way to re-can them is with a bigger can.Comment
Rubber
Don't think I would use rubber fiber here.head has been milled. The first owner was a chick and she only put a 3K on it. The second was a guy who didn't even know there was a kick start lever under the battery bracket and was using a set of vice grips instead. I have a sheet of "Fel-Pro" Rubber fiber 1/16 inch thick, that I'm going to use for the middle drive gear housing gasket. But I'm thinking it might be too thick for the jug, upper case location.
Unless some mods, as others here have mentioned, have been done, I would just spend the $20 or so and go OEM like this one
http://www.ebay.com/itm/YAMAHA-XS110...72d05b&vxp=mtr1979 XS1100 Special (Mad Max, OEM) Current
1980 XS1100 Special
1990 V Max
1982 KZ750 LTD Twin
1974 CB750-Four
Past/pres Car's
1961 Catalina 389/1970 Torino GT 351/1967GTO 12to1 comp./ Roller cam/ T-10/ 456 gear/Tri-power/1967 GTO 400, 1969 Camaro, 1968 Z28, 2001 BMW M Roadster 0 to 60 in 4.5 sec. Jaguar XK8Comment
I have an Athena base gasket here that is brand new and it measures out at 0.55 mm. Hope that helps.2-79 XS1100 SF
Couple of more parts bikes of which 2 more will live!Comment
FOUND IT. second place I looked so no need to tidy the shelf
2 inches of snow and temps dropping so no incentive to stay in the unheated garage. Put the battery tender on the bike.
Let me know when you are through this way or do i need to mail it?.
Phil1981 XS1100 H Venturer ( Addie)
2004 Kawasaki Concours. ( Black Bear)Comment
I think i have the gasket you need i will lokok to morrow.
