barnett clutch frictions
  • CaptonZap
    • Jun 2010
    • 1748
    • Denver
    Hey, on the up side, if I read it right, both of the antagonists are not going to read or respond , so things are good once again.
    CZ
    • jwhughes3
      • 2798
      • Home of the Alamo
      CZ
      CZ always finds the silver lining!
      John
      '81 XS1100H - "Enterprise"
      • onefour
        • Jan 2013
        • 38
        • Nanaimo, BC, Canada
        Originally posted by natemoen
        Ignore him, some of us actually want to see what it can do.
        10-15 lbs on the gauge I installed today. Dont have the bawls or road space to hold it open, I think the 15 may have been boost creep. 3rd gear power wheelie (like 2 inches up) doing 100 (KPH). 2nd gear shot again. Soaked all the frictions in gas yesterday, spun em on a flat surface with 220 grit, and ran the steels over the belt sander. Held yesterday, not holding today Picked up a parts bike and a spare clutch. Might see about machining a centrifugal lockup device... Need steering damper! (waiting on fork bracket) Would also like to throw it on a scale now that everything is about where it will be (race weight)
        81 xs11 special. Blow thru turbo, ihi rhb5 vj11. Tunedish. Getting there... First power wheelie
        82 xj seca 750 - sold...
        79 gs750 - Stock body work, header, velocity stacks and clubmans
        86 fz750 - Sat outside for 4 years. Seized. Latest project.
        81 xs11 standard. White. Full fairing, bags, trunk, etc.
          I used to use 15/40 Rotella oil and had some problems with that. Have you tried changing the oil you use? I've abused the heck out of these motors on regular ol' Castrol 20/50 and the barnett springs.
          And yeah, if you haven't moved that washer on 2nd gear, it won't hold that kind of HP for long.
          • WMarshy
            • Apr 2009
            • 2402
            • Mexico NY
            #35
            I recently watched a Barnett kit on ebay sell that had an additional friction plate for the XS11... Looks like even Barnett knew these clutches could benefit from more plates... I think your waisting you time with everything until you go with another plate. If you can make a custom locking device...
            '79 XS11 F
            Stock except K&N
            '79 XS11 SF
            Stock, no title.
            '84 Chevy K-10 "Big Blue"
              • 5061
              #36
              The barnettts that I got from fleabay were of a minimum thickness to where you would need another steel plate. They are on the shelf of course.
              • WMarshy
                • Apr 2009
                • 2402
                • Mexico NY
                #37
                Did you just get them within a couple of weeks ago? The ones I saw on ebay were NOS Barnett...
                '79 XS11 F
                Stock except K&N
                '79 XS11 SF
                Stock, no title.
                  • 5061
                  #38
                  Well, mine were bought years ago (6?) and were also NOS Barnett. I stacked them and used a caliper and divided by the number of plates and the resulting number was barely above the wear limit.
                  • onefour
                    • Jan 2013
                    • 38
                    #39
                    Snippy snip.
                      #40
                      There was a server change and we lost around a week's with of posts, if that is what you are talking about.
