T fittings
  • Prothec
    • Jul 2007
    • 587
    • Fort Myers, FL
    PET (PETE) is what soda bottles and plastic liquor bottles are made of. I have used the same plastic PET whiskey bottle for a year or so as auxiliary tank for syncing carbs without problems.
    Website/Blog
    • XS1100_OEM4ME
      • Mar 2009
      • 1619
      • Fort Myers, Florida
      Plastic "T"
      I just bought the cheap vacuum "T's" at the auto parts that come in those little multi size packs. Been on the bike about 8 months so far and holding. I do keep an eye on them, and you could go to a bike shop and get the OEM plastic "T's" to be sure
      1980 XS1100 Special
      1990 V Max
      1982 KZ750 LTD Twin
      1974 CB750-Four
      Past/pres Car's
        I think the BRASS BARB 1/4 INCH ID TEE FITTING was about $2-3 at Ace Hardware. Is that too much?
        • XS1100_OEM4ME
          • Mar 2009
          • 1619
          You would probably pay that much for plastic at a bike shop I would suggest you tie them where vibration won't ware a hole in a carb part over time
          1980 XS1100 Special
          1990 V Max
          1982 KZ750 LTD Twin
          1974 CB750-Four
          Past/pres Car's
          • wingnut
            • 695
            • NC
            I went to US plastics on line and got some Y fittings they were much better than the tee for line route. they have been in there your 5 years with no issues.
            wingnut
            81 SH (Daily Ride)
            81 XS 400
            Thomas Jefferson
            • XS1100_OEM4ME
              • Mar 2009
              • 1619
              "y"
              Guess you are talking about these
              U.S. Plastic Corp.® has an extensive selection of polypropylene hose barb tube fittings including elbows, wyes and tees, as well as luers and adapters.
              Same kind of stuff I got at AutoZone, just didn't have to waite I used a "Y" for the Pingel "inlet". You could us a "Y" for the outlet also, but I have two inline filters between the Pingel "outlet" and the two carb "inlets" so the "T" and two ellbows worked better for me
              1980 XS1100 Special
              1990 V Max
              1982 KZ750 LTD Twin
              1974 CB750-Four
              Past/pres Car's
                That link shows polypropylene. I think that petroleum industry standards for oil and gas lines are usually HDPE which is high density polyethylene. I saw that link on the page...
                Heck, I would go with brass if I could find the right fittings!
                • XS1100_OEM4ME
                  • Mar 2009
                  • 1619
                  ACe
                  jetme said Ace has them in brass for a couple bucks each
                  1980 XS1100 Special
                  1990 V Max
                  1982 KZ750 LTD Twin
                  1974 CB750-Four
                  Past/pres Car's
                    • 3193
                    Whatever plastic crap those filters I bought from Mikes XS were made out of did not withstand use with gasoline. Damn near burned one of my bikes down due to that filter.
                    Heat is another issue with plastic Tee's in that they will get warm enough behind that engine to distort is made of the wrong stuff. Again I point to the Mikes XS filters as they actually deformed from the engine heat.
                    Plastic is not plastic in all cases. Be sure if not using brass to find out before a mishap if they are gasoline suitable.
                    • XS1100_OEM4ME
                      • Mar 2009
                      • 1619
                      Filters?
                      What filters did you get form mikes that failed? Were they close to heat, or just gas ate them
                      1980 XS1100 Special
                      1990 V Max
                      1982 KZ750 LTD Twin
                      1974 CB750-Four
                      Past/pres Car's
