ignition coil replacement
  • 650mark
    • Jul 2012
    • 307
    • Mesa, Az.
    if this has already been discussed, sorry. i have a stock '80 xs1100 special. i would like to replace/upgrade the ignition coils. does anybody sell new replacements that simply bolt on without a lot of mods to mounts or wiring? brand? part number? any suggestions will be appreciated. thanks
    I'm not aware of any 'bolt-on' aftermarket replacements. There's some Honda units that will bolt on, but you'll be limited to finding used ones.
    It's not that big a deal to install new aftermarket, look here: http://www.xs11.com/forum/showthread.php?t=4868
      • 2096
      Here's what I did.
      Start with post #1489 in this thread:
      ...or search Dynatek coil mod and PLEASE stay away from Mikes XS coils as they are the 3C type (Cheap-China-Crap)
      P.S. These are installed on my '80G
      • Lamric
        XStremely XSive(Deceased)
        • 410
        • Kenley, Surrey, England
        'nother option is Mikes
        or even VF1000 coils
        Brian
        XS1100 LG "Mr T", SG "ICBM" & FJ1200
        Check out the XS Part Number Finder
        Be not stingy in what costs nothing as courtesy, counsel and countenance.
          Lamric,
          We are finding that all of the coils from Mikes are pretty much junk. Failures in 5k miles or less. And since the turn over in ownership, things there seem to be even less quality parts in some cases.
          I have installed the VF1000 coils in a couple XS1100s and it goes pretty smooth and easy. The toughest part is finding copper core wire from my experience. I have had no luck trying to use the carbon core wires, though others have been successful with the product.
          • spayne83
            • Jan 2013
            • 159
            • Campbell, CA.
            I second that on Mike's. I just got a set and the attachments for the primary wires broke on both coils. Avoid at all costs.
            79 SF 3H3 Engine, 145/45 Mikuni Jets, El Cheapo Pod Filter Mod w/ EMGO Pods, Coil Repower w/ Dyna Coils, Accell Wires and Side Gapped Plugs, 78 Mech Advance, 4-2 Turnouts
            • Lamric
              • 410
              Originally posted by DGXSER
              .... all of the coils from Mikes are pretty much junk. Failures in 5k miles or less. And since the turn over in ownership, things there seem to be even less quality parts in some cases.
              Sounds like this Tech Tip should be removed then.
              Brian
                • 2096
                I'll Second that Emotion
