ignition coil replacement
    replied
    Originally posted by Lamric
    Sounds like this Tech Tip should be removed then.
    I'll Second that Emotion
    Leave a comment:
  • Lamric
    replied
    Originally posted by DGXSER
    .... all of the coils from Mikes are pretty much junk. Failures in 5k miles or less. And since the turn over in ownership, things there seem to be even less quality parts in some cases.
    Leave a comment:
  • spayne83
    replied
    I second that on Mike's. I just got a set and the attachments for the primary wires broke on both coils. Avoid at all costs.
    Leave a comment:
    replied
    Lamric,
    We are finding that all of the coils from Mikes are pretty much junk. Failures in 5k miles or less. And since the turn over in ownership, things there seem to be even less quality parts in some cases.
    I have installed the VF1000 coils in a couple XS1100s and it goes pretty smooth and easy. The toughest part is finding copper core wire from my experience. I have had no luck trying to use the carbon core wires, though others have been successful with the product.
    Leave a comment:
  • Lamric
    replied
    'nother option is Mikes
    or even VF1000 coils
    Leave a comment:
    replied
    Originally posted by 650mark
    if this has already been discussed, sorry. i have a stock '80 xs1100 special. i would like to replace/upgrade the ignition coils. does anybody sell new replacements that simply bolt on without a lot of mods to mounts or wiring? brand? part number? any suggestions will be appreciated. thanks
    Here's what I did.
    Start with post #1489 in this thread:
    ...or search Dynatek coil mod and PLEASE stay away from Mikes XS coils as they are the 3C type (Cheap-China-Crap)
    P.S. These are installed on my '80G
    Leave a comment:
    replied
    I'm not aware of any 'bolt-on' aftermarket replacements. There's some Honda units that will bolt on, but you'll be limited to finding used ones.
    It's not that big a deal to install new aftermarket, look here: http://www.xs11.com/forum/showthread.php?t=4868
    Leave a comment:
  • 650mark
    started a topic ignition coil replacement
