I am replacing the float bowl screws and need to know the length and size-anyone?
float bowl screw size
1997 Jeep Cherokee 4.5"lift installedTags: None -
I ended up buying mine at BikeBandit.com I think MikesXS has them a little cheaper but not by much. It's real hard to find a screw that you can modify to fit. They are a real bugger to get sealed up cause they are such a precision fit.
You buy them here at MikesXS
https://www.mikesxs.net/product/48-0778.html"The Hooligan" XJ1100, Virago Gauge Pods, Screaming Eagle Mufflers, K&N Filter, hand made rear fender, side covers, and solo seat, round bar conversion, small headlight, tail light, and cat eye turn signals, chip fuses, rewired the right way.
Pics: http://s1236.photobucket.com/user/ya...?sort=6&page=1 -
Not the drain screw- the 4 screws that hold the float bowl on.1980 XS1100 SG
1997 Jeep Cherokee 4.5"lift installedComment
JIS head, 5 X .8 mm thread, 14mm long, with split lock washer.
Another mm or so in length won't hurt you, I wouldn't go under that. The head is a JIS must.
Most well stocked Ace Hardware stores will have metric screws. Take the bowl with you to see if the head fits.
Crazy Steve was selling stainless steel Allen heads for the carbs, and he might still have some. A PM would answer that question.
CZComment
JIS-what does that mean?1980 XS1100 SG
Bike bandit has discontinued the drain screw and also the float bowl screws.1980 XS1100 SG
Sent you a PM....Fast, Cheap, Reliable... Pick any two
As CZ stated, AceHardware or Tru-Valu HAS what your wanting. I went with stainless allen head screws from there. Lots of choices in their 'specialty' trays.JIS head, 5 X .8 mm thread, 14mm long, with split lock washer.
CZ81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
Crazy Steve has hooked me up!Thanks Steve!1980 XS1100 SG
OK i gotcha but kind of hard to get actual screws so i went with screws from carzy steve.1980 XS1100 SG
