Float level checking
    • 3193
    I guess I get to fall into the range of anal. I get 48 mpg @ 70 mph. Anal Rules!
    • LoHo
      • Sep 2002
      • 1342
      • Fresno, CA
      "That bike would run if you measured the fuel level in the bowls... "
      Doing that right now with my Borg-Warner MegaNuke 5000 float bowl Stoichiosynchrometer...22.999992, 22.999993, 22.99994...
      • CaptonZap
        • Jun 2010
        • 1748
        • Denver
        Wait a minute, while I get my anal out!
        Let's see, a Canadian gallon is 1.2 US gallons, so the ratio is 1 to 1.2, so 40 mpg is to one, as X is to 1.2. Solving for X, not rounding to least significant digit, we get 48, and we will allow a fisherman's fudge factor for the 70 MPH. (Might the eyes be tricked into thinking that KPH looks like MPH?)
        You guys, tsk, tsk LRL
        CZ
          • 3352
          Nice job with the stoichiometric flux capacitor measuring device, dibs on it next. They sell them at Harbor Freight?
          On a serious note, do you boys that do the fuel measuring method measure to see if your floats are true to begin with? I set mine last weekend on the 1980 G model I am rehabbing with the stoichiometric flux capacitor measuring device and checked each side of the float and 1 float and needed to be adjusted a decent amount to bring each side to the same reading.
          2001 ZRX 1200
          1982 Seca 750
          1983 Nighthawk 550
          • newmaac
            • Dec 2002
            • 369
            • San Jose, CA
            #35
            Still here
            Nope, not scared away!. Just busy working. Doesn't it suck when work gets in the way of real life??
            Man....did I touch a nerve here, or what?
            I appreciate all the input. I certainly wasn't looking to start an e-argument, just looking for a fitting.
            I have done the measuring, but always wanted to know the actual fuel level anyway. Call it curiosity.
            I will go tomorrow and grab some grease fittings.
            Thanks guys.
            Ride well
            PS
            Do I have to buy motorcycle oil, or is it OK to just use what I put in SHMBO's Pinto??
            (ducking and taking cover)
            Mike
            1980 SG "Angus"
            • CaptonZap
              • Jun 2010
              • 1748
              • Denver
              #36
              Originally posted by newmaac
              Nope, not scared away!. Do I have to buy motorcycle oil, or is it OK to just use what I put in SHMBO's Pinto??
              Trouble maker, huh?
              We've seen your type here before!
              I hope you're proud of yourself!
              CZ
                • 3352
                My error to get into a frank discussion not knowing the parties involved, sorry that you guys were witness to that.
                2001 ZRX 1200
                1982 Seca 750
                1983 Nighthawk 550
                • LoHo
                  • Sep 2002
                  • 1342
                  • Fresno, CA
                  #38
                  During my search for a solution to a no-spark condition, I did various other "repairs" to convince myself I was making progress. One was a cleaning and partial rebuild of the carbs. The kit had the Viton tips I have always lusted after. I had taken the carbs apart to clean them, awaiting the kits, and never really compared the parts, which all seemed to fit.
                  I just took my carbs out again...these look the same, right?
                  Oh, and Newmaac, do you have more than one bike? Then you should be using two-cycle oil.
                    • 3352
                    Yeah, but what if he has 3 bikes?
                    The needles are different, I think you picked up on that... The tips are different profiles/tapers, the bodies have slightly different architecture. The one on the left looks like the ones in my 80SG/G carbs, but yours is missing the hanger.
                    When I took apart the 80G carbs a month ago, I found a needle just like the one on the left in the picture, without the hanger on it. The other 3 had the hanger.
                    The other needle isn't one I'm familiar with.
                    2001 ZRX 1200
                    1982 Seca 750
                    1983 Nighthawk 550
                      #40
                      Is the plunger needle stuck for the one on the left? I have seen stuck needles before...
                        • 3352
                        Me thinks the one on the right has the plunger sticking too far out or it's the wrong needle for the carbs. Look at the taper/size of the the right needle tip, not correct either.
                        2001 ZRX 1200
                        1982 Seca 750
                        1983 Nighthawk 550
                          • 3193
                          #42
                          CZ
                          Hey CZ I also own a calculator and did the math before posting as this is a "mostly" american member site. I know I am anal about setting my carbs up because I sure do not want to run too lean and burn a piston. I love going fast. Too rich or too lean does not allow the high speeds I like to run every once in a while.
                          I also have enough bikes that if one does not run for weeks or longer because I did not fix something, it simply does not matter. So I take the time to do it the way I like.
                          Each to his own as everyone has to ride the bike they ride. Could be a worse answer than just setting them by measurement! Could send it to a dealer and get them to do it.
                          • mack
                            • 2411
                            • Ontario, Canada
                            #43
                            LoHo
                            I commented on those needles about two years ago.Cant find it now. I took measurements from the top of the valve itself to the pivot point for the float shafts I think. There are actually at least three types of needles used on our carbs. All have different profiles and lengths. The bottom line was that the needles and valve seats are specific to each other, not interchangeable. As a side issue, I also talked about the crappy plastic foam floats from off shore. They are not only different from float to float but also from side to side of the same float. I'd use brass everytime if I could.
                            mack
                            79 XS 1100 SF Special
                            HERMES
                            original owner
                            81 XS 1100 LH MNS
                            SPICA
                            78 XS 11E
                            IOTA
                            https://youtu.be/wB5Jfbp6SUc
                            https://youtu.be/RaI3WYHSuWA
                            Frankford, Ont, Canada
                            613-398-6186
                              • 3352
                              Good info, Mack.
                              2001 ZRX 1200
                              1982 Seca 750
                              1983 Nighthawk 550
                              • Petersg_99
                                • Apr 2012
                                • 184
                                • Phoenix, AZ.
                                #45
                                2 cycle oil
                                LoHo:
                                If I have 4 bikes and one's a 2 stroke, what type of oil should I be using???
                                Guy
                                1980 XS1100G - Frankenstein - resurrected from the impound lot
                                1991 Suzuki GS500E (not running yet)
                                2003 Burgman AN400 - Blue Belle
                                2005 Burgman AN400 - Silver Belle
