So I made a big mistake today that I'm pretty sure jammed my engine. My #2 spark plug hole threads were a little stripped so I went to fix them with a spark plug thread repair kit. I had to tap the hole blew what I thought was all the shavings out then put the new threads in there. Put everything back together and went to crank it. The engine barely moved and then it just wouldn't move anymore. I tried the kick starter and the engine still wouldn't move. I'm thinking there is some metal it there between the piston and cylinder wall
What can I do? I'm probably going to put another engine in my bike if this is going to require disassembly of the engine like I'm thinking.
Please help.
Please help.
I SHOULD OF KEPT IT!!!
