Jammed my engine.
  • mack
    • 2411
    • Ontario, Canada
    What Steve
    said, but be careful doing that to, there was a thread not too long ago about someone bending valves while doing his shimming on the bench. Apparently the head had both cams installed and he had it sitting flat on the bench. When each cam was rotated using a wrench he bent some on each side.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    • LoHo
      • Sep 2002
      • 1341
      • Fresno, CA
      Geez, I never thought about pushing that valve over with the tap. Bummer!
      • mmaddix
        • Jul 2011
        • 232
        • Beaufort, SC
        Originally posted by BA80
        That 80 engine won't run as strong as the 79. Also, if your not familiar with the engine your putting in it would be a good idea to go ahead and do the fix on the gears while you have it out. It's a lot easier on the bench than in the bike.
        My 79 engine had problems so it didn't run that strong. My 78 was way stronger than my 79. I should of looked at the gears but i needed to get the bike running because every day i don't have my bike i have to spend an extra $20 on gas for my 99 expedition and i wouldn't of had time to fix them till next weekend. And the guy i bought the engine from told be "all the gears are good"... So i put it in my bike and guess what second gear is slipping. Now in a few weeks i will be fixing the gears by flipping the bike over (it sucks I've done it 3 times so far)
        USMC 2005 - Present
        79 XS1100F -Mileage unknown - Clubman bars, aftermarket headlight and speedometer, 4 into 1 straight through exhaust, TopCat's fuse box, 1980G rear fender - Daily driver - My first Motorcycle
        78 XS1100E - Rebuilt And Sold I SHOULD OF KEPT IT!!!
        • mmaddix
          • Jul 2011
          • 232
          • Beaufort, SC
          I never thought about that either but now i know and hopefully everyone else will learn from my mistake.
          USMC 2005 - Present
          • LoHo
            • Sep 2002
            • 1341
            • Fresno, CA
            It made me think because I did a HeliCoil on one (the PO had JB Welded a plug into a sloppy hole). I did a finger sweep to see if it was clear, and wadded in a paper towel loaded with gear grease to catch the shavings. I guess I got lucky, because the valves never entered my mind.
            Good decisions come from experience, but a lot of experience comes from bad decisions. I think Will Rogers said that....
            • mack
              • 2411
              • Ontario, Canada
              2 cd gear
              I was wondering if you have spoken (politely of course) to the kind gentleman who sold you the motor and lied about the gear problem
              mack
              HERMES
              original owner
              81 XS 1100 LH MNS
              SPICA
              78 XS 11E
              IOTA
              613-398-6186
              • mmaddix
                • Jul 2011
                • 232
                • Beaufort, SC
                Not yet. I was pretty heated when i put it in second and it slipped. If he was close by i would of been over there immediately but he has a business about am hour to an hour and a half away and i just decided to spend time with the wife and kids instead of going down there all p-ed off.
                USMC 2005 - Present
                  Good choice........as that would be wasted time that could be better spent, and that three hours wasted would have that lower shaft assembly out and on the bench.
                    • 9980
                    Took it out on SWMBO eh? Not sure that was a goodmove.
                    • mack
                      • 2411
                      • Ontario, Canada
                      Still
                      Good move. Nice to see a young man show patience and fore thought at such a time. Still, I'd make a point of seeing him again, just to let him know that he didn't pull one over on you, and that you are the better man in how you handled it. I'd also tell my friends to watch out dealing with the shady pr...k.
                      mack
                      HERMES
                      original owner
                      81 XS 1100 LH MNS
                      SPICA
                      78 XS 11E
                      IOTA
                      613-398-6186
                      • mack
                        • 2411
                        • Ontario, Canada
                        Lesson to all
                        who have a spare motor sitting someplace in the shop. Take the time now and pull the gear shaft and look at the gear's, even if they look alright, at least move the washer.
                        mack
                        HERMES
                        original owner
                        81 XS 1100 LH MNS
                        SPICA
                        78 XS 11E
                        IOTA
                        613-398-6186
                        • James England
                          • 3039
                          • North of England
                          At times like this, a thing called a borescope is very handy. I have one. It's like a miniature version of that snakey telescopic eye thing in War of the Worlds... with a handle and small screen at the other end. I bought one a while ago and first used it to indicate to someone why their engine wouldn't fire..... there on the screen was a clear picture of a holed piston.
                          Drop something down the CC tunnel? Or a nut in the sump? etc etc.... a boroscope has loads of uses! It has a built-in LED, auto focus and attachments like a magnetic grabber.
                          Actually, I just found the exact one I bought...... http://www.carbtune.co.uk/fibrescope.html
                          As it says in the blurb, you really can look at your own teeth (I've done it) and, indeed, just about any normally unreachable part of one's body. I checked out my tonsil removal scars. I really should get a life though, eh?
                          • CaptonZap
                            • Jun 2010
                            • 1748
                            • Denver
                            There was a young man with a borescope
                            Who's life, without XS, had no hope
                            of spending his day
                            in a more useful way
                            than viewing the results of a zoetrope
                              • 3180
                              I liked that Boroscope so much I just purchased it online from Morgan. Thanks James.
                                • 9980
                                Now you can peek under doors and stuff too.
