1980 Carbs
    #46
    Originally posted by GLoweVA
    For those lurkers that may be reading this, there's another way to 'measure' your float height without calipers.
    Make yourself a go/no-go gage. I take a small piece of cardboard (or any other sutiable material) and using my ruler, measure off the required amount and put a ink/marker line there.
    (Note: the required height is different for the type of float, sorry don't have those exact numbers in front of me)
    Then you can set the cardboard "stick" next to the float and bend the float tab up or down as needed to get the bottom of the float to match up to the mark on the measuring stick.
    Remember to NOT push the float down, just let it rest on the needle.
    If one side of the float pair is higher than the other, you may need to 'twist' the float to get both floats to match the same height.
    This may get you close but I would say it is not exacting enough.
    • GLoweVA
      • Jun 2011
      • 1957
      • Virginia Beach, VA.
      #47
      I would think that as long as the ruler I use is acurate enough and the line I use to mark the gage with isn't too fat, then it should get me within the tolerance (+-0.5mm) of the required measurement.
      I kind of agree with you about removing the float to make the adjustment, but with the history of the float pins and posts sticking, I find it's easier to make the adjustment with the float on the pin, but just making sure that I don't stress anything else in the process.
      80G (Green paint(PO idea))
      The Green Monster
      Got him in '04.
      bald tire & borrowing parts
      Scarlet
      Got her in '11
      Ready for the twisties!
      81H (previously CPMaynard's)
      Hugo
      Cold weather ride
        #48
        Once you get the pins out the first time as long as you clean it up and shave of the pins so they are loose, they will never stick again.
        • Jay60465
          • Jul 2013
          • 30
          • Westmont, IL
          #49
          Thread Jacking 1980 special Carb Help
          yeah my pins felt like they were welded in (lol). But when I put them back in i did not push them completely in like the PO did. I think this is my last float question. Do I take the the measurement from the floats on the resting position with the carbs upside down. thank you all
          80 SG
            • 8736
            Yes, with the carbs upside down on the bench and float bowl gasket removed, measure from the gasket surface to the highest part of the float. Do not press down on the float, measurement should be taken in it's natural resting position Brass floats, the reading should be 1" (25.7mm). Measure each float bulb (8). Adjust by bending the tang at the float valve, if the other side bulb needs adjusting, carefully bend it in the right direction.
            • MPittma100
              • Aug 2011
              • 2359
              Jetting
              I have had good luck with changing the main and pilot jets from the 78E carbs into the 79SF carbs. Throttle response and warm up is much better. Overall driveability is improved. Getting 3 MPG less (38-35), but worth the change for the added performance.
              MP
              1981 XS1100H Venturer
              K&N Air Filter
              ACCT
              Custom Paint by Deitz
              Geezer Rectifier/Regulator
              Stebel Nautilus Horn
              EBC Front Rotors
              Limie Accent Moves On In 2015
              Mike
              • donebysunday
                • Oct 2012
                • 1737
                • New Berlin, Wi.
                #52
                Auto punch
                Use a pencil style automatic punch for locating your drill mark to remove the pins, much better than breaking off the float tower. DAMHIK
                76 XS650 C ROADSTER
                80 XS650 G Special II
                https://ibb.co/album/icbGgF
                80 XS 1100 SG
                81 XS 1100LH/SH DARKHORSE
                https://tinyurl.com/k6nzvtw
                AKA; Don'e, UD, Unca Don'e
                • Jay60465
                  • Jul 2013
                  • 30
                  • Westmont, IL
                  #53
                  carb thread jacking
                  okay I adjusted all the floats to 25.7mm with a digital caliper from the base w/o the gasket to the top of the floats. Yet the carbs continue to overflow. I was wondering if the float needle valves have to be seated a certain way. Or is there a chance that I actually got defective needles from the rebuild kit? I am using a old tank and using a "t" fitting to feed both carbs, can this cause them to overflow.
                  80 SG
                    • 8736
                    Yes, it can. Another fella on here had the same issue, his aux. tank was too high above the carbs creating too much gravity pressure. Try your aux. tank just slightly above the carbs, not higher than 1'. Also make sure you are feeding fuel to the lower T's only, the upper T's are for vent and are not a fuel inlet.
                    • Jay60465
                      • Jul 2013
                      • 30
                      • Westmont, IL
                      #55
                      carb thread jacking
                      Is there a way to test the float needles. I am thinking if I increase the float height it will cause the float needle to close sooner, thus causing a for sure closure. Is this theory correct? I am not to concerned about driving the bike anytime soon, so I have time to test theories and ideas. Thank you bikerphil for your insight on the aux tank.
                      80 SG
                        #56
                        Don't change the floats in an attempt to fix a flooding problem. The float setting is not the issue. Either the floats are hanging up on the bowl gasket or something is holding the float valve open.
                        You didn't answer Phil's question either. Are the fuel lines connected to the lower T's on the carbs? Are the upper T's open to the atmosphere?
                        • Jay60465
                          • Jul 2013
                          • 30
                          • Westmont, IL
                          #57
                          thread jacking
                          I have the fuel lines connected to the lower t's closest to the bowls then I have the upper t's vented to the atmosphere I never thought to check the gasket overhang ...great call
                          80 SG
                          • dpotter58
                            • Aug 2004
                            • 1846
                            • Southern Maryland
                            #58
                            With the carbs off and empty, hook a tee on the fuel inlets and blow into it. air should pass through. Flip them over to simulate the floats being up and you shouldn't be able to blow air in them
                            1980 LG
                            1981 LH
                            • Jay60465
                              • Jul 2013
                              • 30
                              • Westmont, IL
                              #59
                              thread jacking
                              I like the air test I am guessing you cant put too much PSI cause I think gravity fed is like 3psi or something
                              80 SG
                              • GLoweVA
                                • Jun 2011
                                • 1957
                                #60
                                I got to ask, could it be possible that those 2 floats are bad?
                                In other words, they hava a small leak and thus stop floating cause they fill up with fuel.
                                You'd notice this the first time you pull the bowls off after having them filled and see/feel the fuel inside the floats themselves.
                                Just a thought so that we're covering every contingency.
                                Question for you 78/79 owners, do the older carbs with the screw in float needle seats have an oring like the 80/81 press in float needle seats?
                                The 80/81 have had a few leak past that o-ring and cause overflowing.
                                The Green Monster
                                Got him in '04.
                                Scarlet
                                Got her in '11
                                Hugo
                                Cold weather ride
