1980 Carbs
  • Jay60465
    • Jul 2013
    • 30
    • Westmont, IL
    Thread Jacking 1980 special Carb Help
    I ordered the 1979 rebuild kit from the george guy on ebay, the float needles are shot as with 2 pilots. Will for sure do OEM jets when I go for the final tuning process. I am sure I will be spending many hours using that search box....lol, but again I want to thank everyone for their help.
    80 SG
      • 8798
      Jetting guide...
      • Jay60465
        • Jul 2013
        • 30
        • Westmont, IL
        Any good tips on removing the emulsion tubes. I know they are pressed in from the threads I read. These tubes are stuck in there pretty good. I don't want to mushroom the end of the tubes.
        80 SG
          Unscrew the main jet then use a wood dowel and tap them out. You will push them out from the main jet side into the carb throat.
            Yep, I always have some wooden dowel laying around the shop. That is exactly how I get the emulsion tubes out. I have used it on some I had to really drive out due to the amount of fuel that turned into a brown sand like substance in the emulsion tubes. No damage to the tubes or the threads in them.
            • GLoweVA
              • Jun 2011
              • 1957
              • Virginia Beach, VA.
              Another trick is to pull the main jet out, remove the washer, screw the main jet back in, but not very far, then you can tap on the flat surface of the main jet to get the nozzle to start moving down/out. once it's moved as much as it can, (the jet is now fluch with the tower) you can either take a few turns out on the jet, or like otheres have said find some other persuasion tool to use to push it the rest of the way out.
              Penetrating oils and such will help to disolve some of that nasty stuff that's keeping it stuck in there too.
              80G (Green paint(PO idea))
              The Green Monster
              Got him in '04.
              bald tire & borrowing parts
              Scarlet
              Got her in '11
              Ready for the twisties!
              81H (previously CPMaynard's)
              Hugo
              Cold weather ride
              • mikubuilder
                • Jul 2011
                • 548
                • Westland, Mich.
                MAP torch is your friend, too, if used diligently
                Nick
                1982 Virago 750 (it's alive!)
                • Jay60465
                  • Jul 2013
                  • 30
                  • Westmont, IL
                  1980 carbs
                  I am going to try the wood dowel some more PB Blaster and some heat. I just needed to know how worried i had to be when beating on those tubes. My carbs were(are) also gummed up with that nasty brown stuff, one of the toughest cleaning jobs I ever had so far.
                  80 SG
                  • GLoweVA
                    • Jun 2011
                    • 1957
                    Jay, just remember that there's a guide pin/stud about 1/4" down inside that tower. It fits into the groove of the emulsion tube. Once the tube gets down that far, your dowel may 'hang up' on that 'tit'.
                    The Green Monster
                    Got him in '04.
                    Scarlet
                    Got her in '11
                    Hugo
                    Cold weather ride
                    • Jay60465
                      • Jul 2013
                      • 30
                      • Westmont, IL
                      1980 carbs
                      Gotcha...And the surprises continue...lol...thanks for the heads up. So from that information I take it that you can't twist the tubes out, they have to be pulled straight out.
                      80 SG
                        DO NOT GRAB IT BY THE TOP AND TRY AND PULL IT OUT!!!!!!!! You will damage the top and screw everything up!
                        Only push it out from the main jet area!
                        • GLoweVA
                          • Jun 2011
                          • 1957
                          +1 on that Nate. A very long time ago (before I found this site) I tried 'pulling' them out with some needle nose pliers and I did slightly damage that brass a little, I never did find a replacement, but it wasn't that bad, so it's still in the G.
                          Now, I ALWAYS push them out from the bottom.
                          The Green Monster
                          Got him in '04.
                          Scarlet
                          Got her in '11
                          Hugo
                          Cold weather ride
                          • GLoweVA
                            • Jun 2011
                            • 1957
                            OOPS double posted. using the back button on the browser!
                            The Green Monster
                            Got him in '04.
                            Scarlet
                            Got her in '11
                            Hugo
                            Cold weather ride
                            • Jay60465
                              • Jul 2013
                              • 30
                              • Westmont, IL
                              OK these tubes are stuck pretty good I am thinking. I used some heat (butane pencil torch) and trusty PB Blaster. So I began trying to drive the tubes out and got nothing but a mushroomed dowel rod. So after a closer examination I saw something that peeked my interest.
                              [IMG][/IMG]
                              so what is this brass pin? Does this thing lock the tube from moving or something? Or am I being to nervous trying not to break something.
                              80 SG
                                That is the little locator pin located just down in the tube. That is the in that is in the notch that you can see from the main jet area. It does not go into the tube just holds it from rotating. If you use heat be very gentle with it.
                                You did take the top covers off and remove the slides and diaphragms right?
