Hey guys ,On a 81 special where are the ground wires to the frame connected.I think I read somewhere there are 4.
Grounds
Tags: None
the neg from battery goes to frame near where the key lock
for the side cover is,
then theres another from the frame to the middle drive,
then theres a few ground wires that attach under the reg.pete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
[url]http://www.youtube.com/watch?v=3pA8dwxmAVA&feature=mfu_in_order&list=UL[/url] -
Battery Grounds
Do yourself a favor and ensure that all of the grounds that you install are grounded directly to the battery. Simply run a cable from where the original ground from the battery to the chassis goes to the chassis attachment points of the other chassis grounds.
The idea here is to have direct battery grounds rather than inefficient chassis grounds. Trust me, you will be glad that you made this change. Battery will stay charged better and your entire electrical system performance will be enhanced.
MP1981 XS1100H Venturer
K&N Air Filter
ACCT
Custom Paint by Deitz
Geezer Rectifier/Regulator
Stebel Nautilus Horn
EBC Front Rotors
Limie Accent Moves On In 2015
MikeComment
Battery Grounds
For a better explanation of battery grounds, see the post below on this (XS11.com) site. If the link below does not work, use the search feature and type in battery grounds and look for the "Believe it or Not" post.
K&N Air Filter
ACCT
EBC Front Rotors
MikeComment
