Grounds
  • XS1100carbon
    • May 2011
    • 137
    • Everett, WASH.
    Grounds
    Hey guys ,On a 81 special where are the ground wires to the frame connected.I think I read somewhere there are 4.
  • petejw
    • 2269
    • sydney australia
    the neg from battery goes to frame near where the key lock
    for the side cover is,
    then theres another from the frame to the middle drive,
    then theres a few ground wires that attach under the reg.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
    • MPittma100
      • Aug 2011
      • 2359
      Battery Grounds
      Do yourself a favor and ensure that all of the grounds that you install are grounded directly to the battery. Simply run a cable from where the original ground from the battery to the chassis goes to the chassis attachment points of the other chassis grounds.
      The idea here is to have direct battery grounds rather than inefficient chassis grounds. Trust me, you will be glad that you made this change. Battery will stay charged better and your entire electrical system performance will be enhanced.
      MP
      1981 XS1100H Venturer
      K&N Air Filter
      ACCT
      Custom Paint by Deitz
      Geezer Rectifier/Regulator
      Stebel Nautilus Horn
      EBC Front Rotors
      Limie Accent Moves On In 2015
      Mike
      • MPittma100
        • Aug 2011
        • 2359
        Battery Grounds
        For a better explanation of battery grounds, see the post below on this (XS11.com) site. If the link below does not work, use the search feature and type in battery grounds and look for the "Believe it or Not" post.
        MP
        K&N Air Filter
        ACCT
        EBC Front Rotors
        Mike
